Gateway desktop troubleshooting
Something happened to my e3200 desktop. when i made the power on nothing happened but the online connection light is on. i tried with different cable and power slots.
  • 2 more comments
  • jahmed1971 Oct 28, 2007
    how can it be replaced?
  • nebula Nov 05, 2007
    I have similar problem with my S12 650W? How to check if the PS is operational and good?
  • Charles Stillwell
    Charles Stillwell Mar 03, 2009
    i have the same power supplie.if you turn the main power off and back on again 1out of about 20 times mine turns on.thermaltake wont honor my warranty even though i bought it brand new,fromEbay .
  • Charles Stillwell
  • 38 Answers
You have a bad power supply. You need to get it replaced.
Posted on Oct 25, 2007
  • Alessandro Fuchs Oct 28, 2007
    you can go to any computer supply store, best buy , circuitcity ect, and purchase one of a matching voltage. If you don't know how to do it, those stores will usually do it for a nominal fee
I just replaced the motherboard in my gateway gm5626 desktop computer. I think I connected everything up right, the same way it was before but not 100% sure since I don't have the manuel. When I connect...
All motherboards come with the user manual that explains where the cables go. If you haven't got one, go the the manufacturers web site and down load it.
Mar 24, 2017 | Computers & Internet
GATEWAY E4000 Desktop P4 1.8GHz ,768MB doesn't recognize monitor
Try pulling the ram chips out and see if it turns on.
pull out the cards and unplug the cd and hard drive and see if it turns on,,
If you have no luck then its a bad cpu or motherboard,
Apr 10, 2010 | Computers & Internet
The green power light is on but nothing happens,its a gatway prof
MAYBE IS A BAD MOTHERBOARD SEEN THE PROFILE 4 HAVE HISTORY OF MOTHERBOARDS GOING BAD BUT YOU CAN HAVE SORE IF YOU FIND A NEW MOTHERBOARD AND CHANGE ALL THE COMPUNETS TO THAT MOTHERBOARD AND TRY TO BOOT UP IF IT BOOT UP SOCECEFULL IS A BAD MOTHERBOARD
Oct 08, 2009 | Gateway Computers & Internet
My desk top will not turn on the green light at the back is on does not flash, if i try to turn on the pc the light in front will flashe yellow but the desktop will not turn on
Replace the power supply.
Apparently you are getting power to that, but it is not passing power to the motherboard.
If this does not work, I would suggest the following for troubleshooting:
Open the case and unplug everything but the memory (hard drive, CD, other cards)
Now try to start it. If it starts, it's probably the CD.
If, with only the CPU and memory plugged in, nothing happens, then it's probably the power supply.
The next step would be to replace the motherboard.
Aug 24, 2009 | Gateway 507GR PC Desktop
Audio driver E3200-400
download this utility to install and update all the device drivers for gateway systems
http://support.gateway.com/support/drivers/search.asp?ref=nofind&ct=fn&param=gtwupd.exe
Jul 09, 2009 | Computers & Internet
Gateway 3200S will not power up.
i have a big feeling its the mother board
Jun 04, 2009 | Computers & Internet
Older Gateway e3200 powers on but the screen does not turn on
.. Your board may need flashing..
Remove the side panel.
unplug the system
remove the battery from the main board, pry it loose,
remove memory (rams)
press the power button and hold it for 10 sec
replace battery and rams, plug in and turn on!
if you hear nultiple beeps the memory is damaged and needs replacing
if you hear beeps and slow intervals or none at all processor is damaged
other than that it should boot.
ps. Enter settings or bios and load defaults or optimal then save and exit. ... > after flashing.
Apr 03, 2009 | Computers & Internet
New power supply
CHECK YOUR POWER CORD CHECK YOUR ELECTRICITY THAT LINE IS WORKING
Sep 27, 2008 | Gateway 830GM PC Desktop
GX7022E Gateway computer no power up
*check for the powercord wheather it is good or not
*check the power outlet
*in bios see wheather hardware settings are correct
*open the system then see power switches are connected properly or wheather there is an any loose connection
*check the cpu fan is working properly or cpu is heating and see cpu is placed properly
*keyboard is connected properly
*check jumper settings are proper
Jun 24, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
Computers & Internet Logo
1,398 people viewed this question
Alun Cox
David Payne
David Payne
