Question about Toshiba 50H72 50" Rear Projection Television
Wavy line There is one wavy, fuzzy line down the center of my screen. When I switch to video 1, 2, or 3 mode its not there. The picture also seems faded, or to light. How can I fix this?
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 14, 2007
SOURCE:
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Wavy colored line at upper right corner of set seems like something is pushing from top left and distorting picture from that direction.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 13, 2010 | Hitachi 51F500 51" Rear Projection...
Describe your Canon A95 Fuzzy line problem on images and display.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 19, 2010 | Canon PowerShot A95 Digital Camera
PICTURE IS FUZZY AND DISTORTED
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
May 26, 2009 | RCA HD52W59 HDTV Projection Television
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Green screen with red and blue wavy lines
This is "NOT" meant as "expert" advice...as this is not my area...HOWEVER...I see no one has answered this yet...AND I got some good help from here a year or so ago that worked for me!
When I had a similar "green screen" problem with my SONY projection tv...the guy helped me by having me make "MINOR" adjustments to the red/blue/green etc knobs behind the panel. These were three small black plastic pieces and needed less than a 1/16 of an inch adjustment...try adjusting one at a time and giving it few seconds after each adjustment. It worked for me..at least for a while (till my wife gave it away to a friend because it was "too big"...ah! women!!! LOL)...hope this helps. (NON-expert help!)
Jan 11, 2009 | Televison & Video
Green Background with red wavy lines
*Screen Looks 3-D
*Colors wont align
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Samsung HCN653WX has wavy lines and red and blue ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2008 | Samsung HCN653W 65" Rear Projection...
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Toshiba 50H72 50" Rear Projection Television Logo
89 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
