Question about Fisher and Paykel GWL11 Top Load Washer
Leaking water After a complete cycle a small amount of water comes out from underneath the washer. I tipped the washer back & looked up into the washer & saw a litlle water dripping from a small motor and what I think is the pump. Does this need to be replaced? Where can I find one?
  • 2 more comments
  • bradyma Nov 01, 2007
    I have the exact problem as pmdenny's. I took the pump off, cleaned it, then reinstalled it. The washer worked for a couple of days but now its quit again. I think the leaking water must have destroyed the little motor.
  • rfogle Nov 12, 2007
    mine is leaky too and also makes a loud noise when filling....could it be the pump and how do i replace it?
  • Anonymous Aug 31, 2008
    while washing a load of clothes my wife noticed water on the floor. After unloading it and then without clothes I started to fill the tub. It took a few minutes but the water did appear again from underneath. Is it a seal gone bad?
  • Markar101 Aug 31, 2008
    My wife noticed water on the floor after washing a load of clothes. I filled the empty tub and it started to leak again after a few minutes. It was just filling so nothing was moving at the time. Did a seal go bad on me or what?
I replaced the pump with a new one I ordered from Fisher Paykel in Huntington Beach, CA. It cost $75 and was very easy to swap out. Good Luck!
Posted on Nov 07, 2007
  • 58 Answers
Yes, that is a common problem with those. contact the company and they will help you out
Posted on Oct 31, 2007
water pump, replace
Sep 24, 2017 | Washing Machines
Leaks water only when wasing or draing cycle ubder front of machine
Look for a leaking hose on the pump housing. May be just a loose clamp.
Jun 27, 2017 | LG WM2077CW Laundry XL Front Load...
A small amount of water leaks on the floor at the front right corner during the end of the cycle.
tilt the machine back and have a look underneath with a torch to see if you can spot where its coming from there are a few places it might be leaking from the pump / gearbox seal / hoses / inlet valve let me know what the outcone is and i might be able to help futher
Nov 16, 2011 | Fisher and Paykel GWL11 Top Load Washer
My Kitchen Aid clothes washer is leaking water from the bottom.
HI couple things to check, water hoses coming into washer, tip the washer back and look underneath and see if you can see where its coming from, most common leak on this one is the drain pump which is located right on the front of the motor, if you tip the washer back its a plastic pump with 2 big hoses going into it, they usually crack and leak water from there. They are only about $30.00 to buy.
Mar 29, 2011 | KitchenAid KAWS850L Top Load Washer
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Oil and water leak
Chances are they are not related if the water is clean.These units can run quite a while dripping small amounts of oil. The drain hose is a possibility but there are other places it can leak from. Call a local tech he can run the machine with the cabinet removed and should be able to find the source of the water leak. good luck
Dec 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Gld5860l00ss QuietPower2 water leak
did you fix it yet ? check water line fittings underneath if you can pull a bit out washer to watch underneath when running to see where and when in cycle it leaks don't touch any electrical connections safety first LOL. disconnect power wipe dry and then ren it through a quick wash or other cycle and see.
Jul 10, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Washer leaking water from bottom
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check
Yours Truly,
Jul 30, 2006 | Maytag Atlantis MAV6000 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
175 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
