Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Icemaker want stop making ice
My icemaker will not stop making ice. I turn off the ice maker control and it still makes ice.Help!!
  • 11 more comments
  • afterhours Oct 25, 2007
    Thanks for your post.  How do I determine which board has failed, or would it be better to just replace both.
  • afterhours Oct 30, 2007
    Boards should arrive today. Will keep you posted. Thanks tremendously.  Did find a troubleshoot guide for it and I found that the lamp from the boards were not operating at all.
    Thanks,
    Greg
  • afterhours Nov 02, 2007
    I replaced the boards now, the icemaker will not operate at all, makes no ice, I see the optics on, but no ice.
    Greg
    After replacing the boards, now the icemaker makes no Ice. I see the optics on, but no ice.\
    Greg
  • afterhours Nov 04, 2007
    Mike,
    Installed the jumper and the icemaker did not work. Pulled the icemaker and jumpered T and H and the icemaker did not work. Removed the icemaker, cleared all the all ice in the IM and warmed in too room temp and reinstalled. IM made one cycle of ice and did not make anymore. Is it now necessary to buy a new IM? \
    Thanks,
    Greg
  • afterhours Nov 05, 2007
    The clip is not broken.
    Thanks/Greg
  • afterhours Nov 07, 2007
    Thanks for all your help Mike. I went ahead and replaced the IM, wife was wanting ice! Everything seems to be ok finally.
    Greg
  • Anonymous Jun 11, 2008
    the modular icemaker is stoped.
  • Anonymous Mar 22, 2014
    Very loud icemaker
  • Anonymous Mar 24, 2014
    ice maker
  • Anonymous Mar 27, 2014
    need to find out how to take out the icemaker
  • Anonymous Mar 29, 2014
    not making ice
  • Anonymous Mar 30, 2014
    ice maker does not make ice
  • 290 Answers
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Posted on Oct 25, 2007
  • 4 more comments
  • Michael  Lindley
    Michael Lindley Oct 26, 2007
    They come as a set. Part number is 4389102.
    The one on the right is the one that puts power to the icemaker when it is time to dump the ice.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Oct 30, 2007
    Just wanting to follow up on your icemaker problem and see if you got it fixed.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Nov 03, 2007
    That's interesting. The icemaker wouldn't quit making, now it won't make at all.
    Let's start with the easy stuff first. I suggested that you turn the water off or unplug the icemaker. If you did one of these make sure you have water on and icemaker plugged back in.
    If this is ok, you will want to double check the connections at the boards and make sure they are plugged in correctly. I assume the control slide is moved to the on position also.
    If all of this is correct, you can bypass the board and check the rest of the system.
    Remove the board on the right side.
    You will see two wires in the connector that are black. One is solid black and the other is black with a white stripe.
    Use a small wire to cross these two wires together. You can use a straightened paper clip that is taped up well.
    WARNING There is 120 volts on this wire.
    This will bypass the boards and put the icemaker into a cycle.
    If the icemaker goes through the cycle properly, there is a problem with the new boards. If it doesn't cycle, post back and we will check the icemaker.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Nov 04, 2007
    Greg
    Have you been able to find the problem as I described?
    Post back and let me know what you found.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Nov 05, 2007
    Look at the center of the gear on the icemaker. If the gear has red lettering on it see if the small plastic clip that holds the gear in place is broken. You should not be able to wiggle the gear on the shaft. If so you will need to replace the motor module on the icemaker. This is very common, but it is odd that it would quit making now when it was making too much before.
    Let me know what you find.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Nov 06, 2007
    Now you are at the point where you will need to do some checks with a volt meter. If the icemaker won't cycle with the board bypassed and T and H jumpered at the same time, then the motor module is burned out or the thermal fuse in the icemaker harness has opened. This is a very odd problem.
    The only time I ever see multiple failures in one of these is when the water valve shorts out. This will kill the module switches and the boards. But yours was making ice ok until you changed boards. Very strange.
    With the board bypassed you should have 120v between L and N on the module. If you have that the thermal fuse is ok.
    If the temprature of the icemaker is below 11 degrees F the points between T and H should be closed. If not then the Bimetal needs replacing. This is what you bypass when you put a jumper there.
    You can bypass the boards and jump between L and V and make sure the water valve opens.
    Post back and let me know what you find out.
    Thanks/Mike
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
    slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
    Jan 11, 2013 | Refrigerators
    I have a Kenmore Model 106-55602400 Coldspot and the icemaker stopped working. What do I do?
    The control module has failed on the ice maker. You can replace the control module alone, but I would replace the ice maker completely.
    Here is a link for the control module.
    Here is a link for the new ice maker.
    Oct 15, 2012 | Kenmore Refrigerators
    My uline BCM45A ice maker is cold but does not make ice
    This unit work on the thermostat. When the temperature gets between 10 - 15 degrees it will satisfy the control then turn the compressor off and icemaker will advance. If the control is set too cold then it will never satisfy the control. 1st make sure the thermostat is at the warmest setting. When the compressor cycles off look to see if the icemaker is advancing.If no then replace the control.
    Sep 15, 2009 | U-Line Icemaker
    Keeps making ice, i can't seem to make it stop.
    You have an emitter and receiver in the freezer section...Actually when you slide the lever on the right side in the middle of the freezer section, you break the beam...and it is suppose to stop the ice maker from harvesting ice anymore. If this shut off device fails, it can fail in the on position and continue to make ice. Replace this assemlby sold in a kit and you will be fine. In the mean time, if you can remove the ice maker head and unplug it, that will stop the ice until you can replace the emitter and receiver assembly. You can also shut the water off but the ice maker will continue to operate, just not dispense ice. If extending and waiting on this repair you should disconnect the ice maker.....
    Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
    Ice maker makes ice and won't stop when full
    this icemaker has an electronic control. it could be simple micro switch or the board.
    Jul 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ice maker not working properly
    could be the air damper. try adjusting air control for more air at icemaker.
    May 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Icemaker stopped making ice
    remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
    May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
    Whirlpool ED2FHEXN Side by Side Refrigerator Logo
    1,007 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
