Question about HP OfficeJet Pro L7580 Color All-in-One Printer
HP L7580 When I print, the last edge of the printed document does not get printed...i.e. it cuts off printing at the very end of the document....it just started doing this and I don't know why??
    Genius:
  • 1,601 Answers
Posted on Nov 12, 2007
SOURCE:
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
The black print head has a few blocked nozzles.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 04, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Jul 19, 2009 | HP Office Equipment & Supplies
Hp officejet pro l7580 won't print
Try this. Go to WWW.hp.com and let the website find your printer and install the sotware automatically.
Jun 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Black ink not coming through
I had the same problem. Ended up replacing the black/yellow "printhead" and that corrected the problem.
Jun 08, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
New Vista Computer wont print last line, XP no problem
Using the print or printer setup (I can remember what is actually written) from within word. ensure that the print margins are not to small and cutting off your words, or if the print is appearing close to the edge of the paper when you print, you maybe outside the range of the prints ability to print that close to the edge of the page in whice case you would increase your margins in the print setup (ie from .125 to .375 or .50)
Apr 03, 2009 | Computers & Internet
Printing Backwards
You must have the Mirror image option turned on.
Open a document and select File>Print.
When the Print window opens, select the "Preferences" or "Properties". button.
Click on the Advanced tab. Look for the Mirror Image option. If it says "On", click on it and you will get a drop down menu to change it to "Off".
(BTW, the Mirror Image is used for printing iron-on transfers.)
Jan 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Bottom of page is cut off sometimes printing from vista computer
I had same problem with Vista machine and hp c309 printer cutting off 1/2 of last line. Tried all other listed fixes and none of them worked. Eventually I found a fix that worked for me though.
1. Go to the control panel and select the printer
2. Right click and select Properties
3. Go to the Ports tab
4. Uncheck 'Bidirectional Support'
5. Click apply.
Hope this helps! It worked for me.
Jul 08, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP OfficeJet Pro L7580 Color All-in-One Printer Logo
77 people viewed this question
Clive
Clive
Thomas F. Schneider
