Question about Rockford Fosgate Power 1000BD Car Audio Amplifier
Need tool for amp
My RF Punch 1000bd quit working. I can't find the tool anywhere needed to open the amp up to troubleshoot. where can I find it?
  • 631 Answers
Some of the amps used tamper-resistant socket head cap screws. You can buy the nex bits from Try page 2753.
There are no fuses in it. Are you going to try to repair it yourself?
Posted on Oct 25, 2007
Is a boss ce2800 amp a good amp it says its 2800 watt class d mono block
It's over rated on it's specs and they run real hot when working hard. Make sure to located in an area with good air flow and away from material that may melt.
Nov 15, 2013 | Car Audio & Video
Amp worked fine one day and the next day i get nothing. the red light on the side is on but i dont get any sound. i took the subs that were wired on that amp and wired them on the other punch 800 i have...
did you check all fuses on amp and coming from battery power wire? also check the ground and rca cables connecting to the unit and make sure the remote wire (small blue wire) didnt come lose thats usualy a sign for the red light
Mar 26, 2011 | Rockford Fosgate Punch 800a2 Car Audio...
Do you know where I can fix my Rockford Fosgate Power 1000BD Car Audio Amplifier inside tucson? what could be the best choice? fix it ? or sellin it?
You could open it up and if you are familiar with soldering that is most likely your problem something that was soldered down has come loose.
Mar 03, 2011 | Rockford Fosgate Power 1000BD Car Audio...
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
Can a rf 201s amp push 4-6x9s and 4-104s door speakers
Hello jon_jonmay,
Wiring 4 speakers to each of 2 channels, you will need to wire them series-parallel and run them at 4 ohms. If you wire all 4 parallel, the load will be 1 ohm and the amp is only stable down to 2 ohms.
According to your manual, the 201s will deliver 50 watts into each channel at 4 ohms . So it will be supplying about 12.5 watts per speaker which is about what you get with the average factory radio. They will work OK, but they're not going to be very loud.
Hope this helps.
Apr 21, 2009 | Rockford Fosgate Punch 201S Car Audio...
Is this ok?
yes 2ohm should be fine for that amp no problem
But dont bridge it any lower than 2 ohms.
Nov 26, 2008 | Rockford Fosgate Punch P4004 Car Audio...
Amp gets very hot in as little as 5-10 min.
Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
Nov 05, 2008 | Rockford Fosgate Punch 700S Car Audio...
Punch 40dsm wont power up
There is no reset button, if you've confirmed that you have a good ground and sufficient voltage on the B+ and remote terminals, the ampifier is in need of repair.
If you're interested in troubleshooting/repairing it yourself, read through the following page to familiarize yourself with the inner workings of an amplifier.
Basic Amplifier Repair Tutorial
A common problem on these amps is broken connections on the remote turn-on connector lug. If it's loose in the board, that would be the first thing you'd need to repair.
Let me know if you have any other questions.
Sep 07, 2008 | Rockford Fosgate Punch P4004 Car Audio...
Stopped working
either your amp is blown which it very well could be. or your just hooking something up wrong in the wiring. make sure ur battery wire and small blue amp wire are secure with a good ground
Jul 11, 2008 | Rockford Fosgate Punch 300S Car Audio...
No power
hi, some car amps need a high current remote supply to turn on. first make sure that you are using the proper gauge b+ and gnd cable for this particular rockford amp. then try switching the remtote turn on to this amp thru a simple Relay.(use the remote supply from your headunit as a trigger for the relay). do these connections without connecting any spks or rca line inputs. once amp is switching on then connect all other cables. OR lastly check the main fuse on the RF amp?? cheers
Jul 22, 2007 | Rockford Fosgate Punch P325.2 2-Channel...
Rockford Fosgate Power 1000BD Car Audio Amplifier Logo
83 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
