Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Installing operating system using cmos set up
Hi guys,
im ian from phillipines i just wanna ask if how can i install my os using cmos bec i want to format and fresh install my pc .... any idea?
thanks a lot
  • 38 Answers
Yep. Insert your windows xp disc into the cd-rom dirve. Then boot from the disc and follow through the setup process.
Posted on Oct 25, 2007
Hello.can we ask u something? how we can change the splitcam?because our cam not working in yahoo because my webcam is different installing.i wanna change a split capture.i ccant view this camera A4TECH PC...
Hi Rubygarcia76, Do you mean you are using two web camera or two webcam installed in your pc if so maybe it's better if you are using only one and you know webcam a4tech pc camera is compatible with the operating system win 95, 98, 2000 or nt 2000 win xp or vista if you are using different os beside with all os that i mention this not compatible and if you force to install it the program is still become always not working properly.
Hope this guide will help you.
Best regards,
Lito E. Fidel
Jun 27, 2011 | A4tech PK5
Hi! im using windows 7 starter, can i used vista as my new os?
ye you can, it mean you must downgrade your pc, use vista cd to install it, but you may lost your data at drive C: you must back up your drive c: data before install vista
i hope this helpful
thank you for using fixya
Jan 30, 2011 | Computers & Internet
Hi im trying to install windows 7 on my aspire 4715z, as im starting to start the instalation when an error appear "a required cd/dvd drive device is missing. if you have a driver floppy disk, cd,...
Hi there !
Your windows operating dvd installer is damage. It just the CD/DVDROM drive cannot read your DVD installer because it have too many scatches in your DVD. Just get new OS dvd installer and repair your windows 7 operating system or reinstall the operating system.
Jan 26, 2011 | Computers & Internet
I bought a new laptop, its a Compaq Presario CQ41 that comes with freedos OS, after i on my lappy, there's message asking to choose language.but,after i choose any language or press 'enter', i get the...
This is because of the settings in cmos...
turn on computer,press del or F2 to enter into startup as soon as the computer boot up.... it wil take you to cmos settings.... now go to an option called "disk nativity" in advanced settings.... it wil be enabled by default.... just disable the cmos settings and exit.... now install the operating system, it will get installed without any error messages.....
May 02, 2010 | Compaq Computers & Internet
Hi guys..i got a problem with my laptop cq40.i cant install vista os.3 type os i had tried.but none of them can install.otherthing,is it my cq40 cant use windows xp sp3?
you may need to format your hard drive before installing any operating system on your laptop. also try removing the hard drive, use an ide/sata adapter and connect it via USB or install inside another computer.
use THAT computer to format your hard drive and install your operating system initially and then remove it and place it back in the laptop to finish the process.
Nov 26, 2009 | Compaq Computers & Internet
Dual boot prob
boot to win98 operating system. Insert the XP operating CD. IT will automatically open a window asking you to select Install winXP prof. It will ask for new installation and Upgrade (recommended)
select upgrade and select next and follow the instructions. it will restart and ask you select the os.
select xp in blue screen. install the OS other than C Drive.
please don't ever install in c drive.. do with caution.
Oct 19, 2008 | Computers & Internet
Not boot from factory CD -where is CMOS battery?
Appreciate the direct "Ask Me".
Based on your post/description:
  • Toshiba Satellite 1415-S173;
  • new HDD;
  • would install WinXP.
Your concerns are:
  • media/cable fault;
  • CMOS battery;
  • laptop battery.
  • will not complete format;
  • will not install OS (WinXP).
Proposed course of action and other ideas:
  1. double check the new HDD, verify that the pins are not bent and are seated correctly. If all else fails, return the new HDD and have it replaced;
  2. try partitioning/formatting the new HDD in another PC using a 2.5 IDE to USB external adapter;
  3. clean the lens of the DVD/CD ROM drive;
  4. remove the dead laptop battery and use only the AC power when installing;
  5. most current laptops do not use a CMOS battery;
  6. if you want to revert CMOS/BIOS settings to default, it could be done by pressing on ESC or F1 or as indicated in the display (depends on the version) and set all possible settings to default. Verify that it is set to boot from the CD drive.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 02, 2008 | Toshiba Satellite 1415-S173 Notebook
Having problem installing Windows XP on My Acer Aspire T650 Computer
Before you did the install did you make sure that you set your CMOS setting to check for a cd disk first before booting straight to the hard drive? When you do an install, you must make sure that the computer knows to look for a bootable disk otherwise it will look for an operating system to boot to first. If this is the problem, after you have installed your operating system you must go back and reset your CMOS settings to look for a hard drive or operating system. Hope this help and if it doesn't let me know for further assistance.
Jul 04, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
How can i repair my currupt file
lower capacity pc can slower the system specially xp or vista. try to reformat your pc and try to install win98 os for you to diffenciate the speed between higher os.
Sep 25, 2007 | Microsoft Windows XP Professional With...
Do you want Install any software, or do you want to Install Windows Operating System.Installing Windows in your Computer is a easy thing Just say what software want to Install
Sep 07, 2007 | Red Hat Enterprise Linux ES 3 Standard...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
