Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Noisy it is noisy, i can hear it running in the other room and it makes a rattling noise toward beginning and the end
Our Bosch had a similar problem. I think something was stuck in the pump and causing the rattle. Remove the filter and clean out any gunk and/or water left in the sump. If your model is like mine, the pump cover is on the left and can be removed by unscrewing on Torx screw (I didn't have the right size torx wrench, but mine came out easily by turning it with needle-nose pliers). Lift the cover off and see if something in there is causing the rattle. Clean and reassemble
Posted on Nov 04, 2007
Noisy during spin cycle
Yes that is definitely bearing noise you here.
Jun 21, 2017 | LG Washing Machines
2002 2w 4 cy stick shift. My car is running but there is a rattling or drowneding sound. Not sure if it's timing, water pump or center bearing. How do I know
Timing will not make a noise unless you are under acceleration or load ---Water pump will make a dead rattling sound ( listen to the end of a screw driver on the water pump housing . It will have a deep rumble if faulty)--centre bearing will be noisy when travelling and will produce a vibration at speed . More information as to when the noise is happening and wether the car is stationary or travelling would be a big help.
Jun 08, 2014 | Cars & Trucks
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Would a faulty speed circuit sensor make the car idol noisy like a rattling knocking noise. noise is louder when accelerating.
NO, it sounds more terminal than that, if you have a knocking sound or noise coming from your engine it could be a few different things, 1. big end bearing, need to rebuild bottom end of engine this is the main one, best get it to a mechanic to clarify the problem for you
Feb 05, 2010 | 2001 Hyundai Santa Fe
97 buick park avenue 3800 motor making a noise in the top end but sounds like a knock but hasnt effected the performance of the car just noisy
It is probably a noisy wrist pin on one cylinder,
also known as "a death rattle"
GM had this in their 2.2 engines,
Dec 16, 2009 | 1997 Buick Park Avenue
Have been hearing a rattle. It sounds like it is
did you check all the exahast hangers the exahast might be rattling just guessing though
Aug 15, 2009 | 2001 Oldsmobile Aurora
Jingling noise? 1990 chevy k2500
If you had front disc brakes changed recently, then more than liklely someone forgot to put your anti rattle clip in with the installation. if you can stand the rattle it's not life threatning. if no brake job recently, then open the hood and look for something loose that would be rattling.
Jun 23, 2009 | 1999 Chevrolet Silverado 1500
Washer noise during spin cycle
remove the belt and spin the motor by hand to see if its noisy then the pump.if its the gearbox you would be better to replace the machine,i havent seen to many last more than 5 years the gear box could cost about 500.hope this helps.
Mar 26, 2008 | Washing Machines
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
391 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
