Question about Acomdata E5 (HD080FE5-72) 80 GB FireWire 400 (1394a) Hard Drive
Acomdata no longer recognized
Hi, I'm having a similar problem to one posted previously.  My laptop won't recognize my acomata drive anymore (not in disk mgmt).  The light is constantly red but it seems that the drive is 'on' (when I touch it, feels like it's working away and not dead).  I've tried different USB ports and tried restarting but nothing has changed.  I don't have easy access to another laptop to test that out.  Any further suggestions to the problem??  Can someone please tell me I have not lost my data???
Someone suggested checking drive error logs - where do I find those?
I also had the Red Blue Blink Problem. I Followed Kelvin's advice and swapped the power cable with another AcomData drive. Success! That was quite a scare.
Posted on Nov 30, 2007
Hey Cella, I had the same problem, the LED flashes blue and red and it isn't recognized by the computer.
In my case, I had two of these drives connected to my desktop, one was still working while the other wasn't recognized. I swapped the power supply/ power cords that were connected and voila, it's recognized, all data is still there, no corruption or missing files.
In your case, you can try and contact acomdata and see if they can ship you a replacement or you may have to purchase the power supply.
Hope this helps. Worked for me, should work for you.
- Kelvin
Posted on Nov 25, 2007
    Novelist:
    Champion:
  • 244 Answers
Check your USB Cable connected possible lost contact problem or the power supply of your optical drive.
Hope this will be helpful to you.
Posted on Oct 26, 2007
Hi there, i have a acomata external hard drive, i did format and now its showing me that i have a 7.50GB disk space but actual disk space is 120GB. Can you please help me to find out why is it like that?
format again (assuming your using xp) make sure that the format is FAT-32 or FAT-16 and that the size is 120gb. Then check the drive properties and see if any space has been used. if so how much then post that and i'll work from there.
Dec 21, 2009 | Acomdata HD120U2FE-72 120 GB Hard Drive
Acomdata hard drive Model HD320FES-72
Sounds like the drive has seized spindle... Not good news.
Is it buzzing similar to any of these noises: http://datacent.com/hard_drive_sounds.php ?
What you should do is remove the internal drive from the enclosure and connect it directly to the computer. If still buzzing then it's a real mechanical problem...
Nov 02, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Sep 12, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Drive not recognized by desktop.
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Connection
Jun 27, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
My XP computer not recognizing drive anymore
Same thing just happened to me, trying to find a solution as I write, if I find anything I will post back!
Dec 08, 2007 | Lite On LH-18A1P DVD RW Dual Layer Burner
Hard Drive not recognized
Hi eric,
Read this article.. I've got a lot of help from it when i had a similar problem sometime ago..Good luck!
http://murfsgarage.cybertechhelp.com/Hard%20Drive%20NR.htm
If there's anything that you couldn't grasp then feel free to post back..
Nov 21, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Acomdata E5 (HD080FE5-72) 80 GB FireWire 400 (1394a) Hard Drive Logo
407 people viewed this question
Top Acomdata Computers & Internet Experts
Donna Sander
mark
mark
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
