Peg Perego Gaucho Rock'in Logo
Posted on Jun 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WIRING FOR PEREGO 12 VOLT
DIAGRAM FOR WIRING
Adam Fjeld
Level 3:
Genius:
  • Peg Perego Master 1,508 Answers
  • Posted on Aug 17, 2017
Adam Fjeld
Peg Perego Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542014
Points
1761
2 Related Answers
Anonymous
  • 60 Answers
  • Posted on Mar 11, 2009
SOURCE: 12 volt rechargeable battery
Walmart has them> I would definately buy from them because if you get it home and then find out that you  have other problems than a new battery, you can always take it back.
romney2012
  • 156 Answers
  • Posted on Jun 23, 2009
SOURCE: wiring specs for peg perego polaris 700
I would contact the repair help at
http://www.shopjandl.com/
They seem to know a lot about these toys
Need wiring diagram to change from 6 volt to 12 volt. Have '48 8N tractor still on old 6 volt system need to rewire to 12 volt system
Only thing needed is to change battery , leave wires alone , unless there is a wiring problem , wiring diagrams are avalible on internet, pdf ...
Nov 19, 2017 • Garden
How to change battery
you need the thing that connects to the battery and plugs into the wall. You can get one at walmart for around $40 Peg Perego 12 Volt Quick Charger for Peg Perego John Deere Polaris and...
12v wiring diagram for perego johndeere gator
Below is a the wiring diagram for the Peg Perego John Deere Gator HPX. I also included the parts diagram.
If the images are too small you can find them online (as well as replacement parts & manuals from a Peg Perego service center) here: http://peg-peregoparts.com/diagram.php?num=IGOD0055
see also: http://peg-peregoparts.com/vehicle.php?num=IGOD0055&display=overhaul
Wiring Diagram
c321785b-edfb-474f-aeb5-b95b778733bd.jpgParts Diagram
18872932-1308-4a2d-be44-39e68011f567.jpg b
Best of Luck!
I want to test motors on pergo gator can i hook up reg 12 volt lawn battery to test that they spin or can i test charger
no don't hook it up to regualr 12 volt battery, first check the voltage of the peg perego battery and make sure that its putting out 12 volts, then you can use jumper wires and connect to the motors with the peg perego battery and verify that they work
Does the 12 Volt battery for Peg Perego John Deere need to be replaced each year?
nope, but you should maintain it with a charger when not in use for a long time
We just replaced the battery and it worked fine
Use a meter to confirm whether the battery is still working. The meter should read around 12-13 VDC if the battery is good. The 12 Volt Peg Perego battery is made with 2 6 volt batteries connected in series. Maybe the connection broke when the battery fell out. Check the connection and also check with a meter if either battery is pumping out 6 volts.
42helpful
Wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Nov 05, 2009 • Boating
1helpful
2answers
I need a new batery charger for my peg perego gator hpx 12 volt. where can i get one?
I bought my Peg Perego Charger at
http://www.shopjandl.com/mecb0034.html
They fit the 12 volt blue batteries for Peg Perego.
Hope this helps
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
