Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Hummm There a constant humming noise coming from the tv. It sometimes goes away but its mostly humming. Also from time to time, you can see a wavy arrow shape that moves from the bottom to the top of the screen. Any idea on how to correct this?
My tv did this while it was still under warranty. It was diagnosed as cracked horizontal deflection coil.  They replaced the coil.  I hope you can get it fixed. I know it is very annoying.
Posted on Oct 31, 2007
Low hum or buzz in fridge/freezer (mostly from the freezer side)
Hello, the solution was the ASM control circuit board, ordered one online for around $100 and replaced it
Thanks
May 30, 2010 | Refrigerators
Humming or squealing noise when tv is turned on (model 32LG30)
Be sure you have installed the stand scresw weather or not you are using the stand.
The back panel can vibrate without the screws.
Other sources of a hum are the coils on the power supply.
The power supply would have to be replaced to solve the issue.
Jan 19, 2010 | LG 32LG30 32 in. LCD HDTV
There is a humming sound coming from the front end of my 1999 oldmobile alero. Only happens when the car is moving. I dont hear itat idle or even when pushing the gas at idle. could it be my transmission...
Hello! If the humming noise is speed related(gets louder as vehicle speed increases)check front wheel bearings. If the noise goes away when turning one way or the other then it will most likely be in the front wheel bearing. If you turn the wheel(while moving)to the right and the noise goes away it is on the right side. If you turn the wheel to the left and the noise goes away its on the left side. Hope this information helps!
Sep 13, 2009 | 1999 Oldsmobile Alero
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Tv has what sounds like a humming noise by where the bulb is
sounds like the color wheel problem.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Dec 11, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Zenith C27V22 27" TV loud humming noise
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
Jun 19, 2007 | Zenith C27V22 27" TV
HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Apr 01, 2007 | Samsung HLN617W 61" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
