Question about Fisher and Paykel AeroTech - OS302M Electric Single Oven
How to replace a fan bake oven hidden element
The hidden fanbake element in my Classique oven has burnt out and needs to be replaced.  How do I go about replacing the element?
  • 38 Answers
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
Posted on Nov 22, 2009
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
How to replace the lower, hidden bake element in the lower oven of an Electrolux Icon oven
You need a 1/4 or 1/16 mm. to take it out, they always have a simgle plug.
Nov 13, 2013 | Electrolux Ovens
I have a Tricity Bendix Built in oven TBS749. I have problems when baking as previously tried and tested recipes do not bake properly with burning on the top but the inside not cooked. I had noticed that...
Have you tried to turn the oven on to preheat and observe that the upper and lower heating elements alternately go on and off? Could be that 1 of your elements is burnt out and need replaced.
May 02, 2017 | Ovens
The fan still circulate on fan bake but no heat
IT SOUNDS LIKE YOUR HEATING ELEMENT HAS BURNT OUT ,FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE BACK PANEL ON REMOVE ALL THEM AND THE PANEL YOU THEN SHOULD SEE THE ELEMENTS REMOVE THEM BY PULLING OUT THE PULG HOLDING THE ELEMENT IN THEN TAKE IT TO A ELECTRICAL SUPPLY STORE FOR REPLACEMENT REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE.
Dec 04, 2009 | Baumatic B185 Stainless Steel Electric...
I need to replace my bake element on the bottom of the oven. I have removed the plate but do not know how the wires disconnect
they are just a push-on spade terminal,pull them off replace the element and carefully push-on the terminals to the element
Nov 18, 2009 | Whirlpool GSC278PJS Oven
Our wall oven will broil, but will not heat up to bake. Also the fan to cool down is super loud, where do I start? It' a GE model-JGRP18GEL5BG
IT SOUNDS LIKE THE HEATING ELEMENT HAS BURNT OUT AND THIS IS WHY YOUR OVEN DOSENT HEAT UP, I WOULD ALSO SUGGEST THE REASON YOUR FAN IS LOUD IS IT MAY BE OFF BALLANCE AND LOOSE AND AS ITS TURING IT BANGS ON THE FRAME , SO REPLACE THE ELEMENT AND FIX THE FAN .
Nov 09, 2009 | Ovens
BAKE ELEMENT
not sure I can help but will try. If your oven is fan forced you will probably find a cover that removes inside the oven to reveal the fan and also the element. Some elements are screwed in. Sometimes you have to take the back panel off also to get to the wires to remove them without breaking the lugs off. Hope this helps.
Regards
Bryan
May 27, 2008 | Ovens
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
Feb 24, 2008 | Ovens
Fisher and Paykel AeroTech - OS302M Electric Single Oven Logo
1,421 people viewed this question
Top Fisher and Paykel Ovens Experts
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
