Home | Sharp | AF-S80FX 8,000 BTU Comfort Touch Air Con... | A/C unit fell out win...
Sharp AF-S80FX 8,000 BTU Comfort Touch Air Conditioner
Problem for Sharp AF-S80FX 8,000 BTU Comfort Touch Air Conditioner
A/C unit fell out window, pulled out wiring
By jhelm36 on Jun 04, 2009
Hello -- I have a Sharp AF S85FX-A window A/C unit that fell out the window & ripped out the wires. No damage to the components internally other than some broken plastic and what not, but I am unable to figure out where the wires go. I was an automotive A/C tech, but house electrical is beyond my realm. Anyhow, there are three wires within the cord that pulled cleanly from the terminal connectors and bent the blades on the ckt board but didn't break them. They are approx. 10/12 gauge, black & white and those are the wires that had blade connectors on them. There is also a green wire in the middle that appeared to pull apart from the one internally and break. The power wires go to the ckt board which is marked "power" and "fan." I'm not sure which go where. Also, it's baffling that the heavy rubber insulation around the power wires where it goes through the chassis I can see no entry point and no insulation pulled apart on the inside.
Please help! Dyin' here!
John, Vancouver, WA
Comments:
Jun 05, 2009
- Was cleaning unit since I had it torn apart and noticed a wiring schematic sticker on the frame. Duh! Can't believe I didn't notice it before, but that's the information I needed. So problem solved on my own.
j
Solution #1
posted on Jun 07, 2009
Not Rated)
james3751
Rank: Guru
Rating: 91%, 169 votes
You should have two terminals marked L1 L2 That is wherer the two power wires go. The green is connected to ground. Rsuty
Was this helpful?
Yes
No
Popular Solutions for Sharp AF-S80FX 8,000 BTU
Questions and Unsolved Problems for Sharp AF-S80FX 8,000 BTU
Do you recommend Sharp AF-S80FX 8,000 BTU Comfort Touch Air Conditioner?
Answer
Answer
I have a RHEEM AC unit and it's not coming on. What can it possible be?
Answer
need fan motor for inside unit for galanz split system airconditioner model AUS-18HR53FA2
Answer
hi im a 3rd yr appentice refrigeration mechanic ,,i need the following for an assingment ,flow... (More)
Answer
does not seem to blowing out cool air not sure how to use the remote control
Answer
my air conditioner keeps turning off by its own self what should i do...
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AF-S80FX 8,000 BTU...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
