Question about Black & Decker S500 ScumBuster Handheld Vacuum
Change blade on old model Black & Decker circular saw
Cannot find a "lock" to hold the blade. How do I remove it?
  • ginsfort Nov 12, 2007
    model 7392 black and decker circular saw cant find blade lock to remove blade
  • ccostello Nov 24, 2007
    I have the same problem... Cannot find a locking mechanism to lock the circular saw blade when trying the replace the blade?
    Best regards,
I drp a screwdriver through one of holes in the blade; that "locks the blade" when the screwdriver comes up against the sole plate. Works great for tightening as well.
Posted on Mar 09, 2008
WHERE CAN I GET A user manual for a Black & decker ORA 32.4 vacuum please
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Black & Decker model by clicking the link below.,BDH3600SV.pdf?_ga=2.47809504.690377823.1513544467-1337893124.1494963821
You can purchase a wide variety of high quality Black & Decker replacement parts for your Black & Decker vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Apr 17, 2016 | Black & Decker Vacuums
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
Hi. I have an older fein multimaster msxe 636 II. The blades have round bolt holes. The new models have the star type holes. Can I use the star type blades since they are more available?
With respect to the above "answer", this tool has NO locking lever! It uses only a set screw to hold blades in place. It so happens that newer "star" mounting blades will fit into this tool easily, One must center the blade so the fingers of the star are outside of the raised circular surround of the hole. A washer (use a larger tapered one) and the set screw will then press the blade against the back surface of the bit holder. Tighten up this assembly, turn it on a cut away!
Dec 30, 2009 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Vacuum Cleaner Bags
Aug 27, 2008 | Black & Decker HV6000 Bagged Handheld...
I suggest calling customer service.
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
Remove sole plate and beater bar.
Remove control knob by prising between yellow plastic side of knob and casing using wide bladed screwdriver.
There three torx headed screws holding the clotch assembly in place. Two are visible but the third is accessed via a circular access holein the main casing.
When these three screws are removed the clutch assembly can be pulled out. the thinner belt driven by the motor needs easing over the motor shaft.
There are two screws holding the end plate onto the clutch assembly. remove these, twist the end plate and remove. note where the fibre clutch plate and the metal plate fit and replace this belt.
On opposite end prise off spring washer and this assembly comes off the reveal the belt.
Refitting is the reverse.
Have a look on you tube and type in replacing clutch on Dyson DC4 as there is a 10 minute vidio that is quite good!!
Hope this helps!!!!!
Dec 12, 2007 | Vacuums
Black & Decker S500 ScumBuster Handheld Vacuum Logo
3,051 people viewed this question
Top Black & Decker Vacuums Experts
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
