It depends upon the mfr's requirements. Consult your owner's manual or read the labels at the auto parts store very carefully. Every major mfr has there own specification number beginning with the mfr's Letter Code and then some numbers. If the mfr's letter code isn't listed for the mfr of your vehicle, then don't even bother to consider it. The use of a particular ATF is not determined by mileage, it's determined by the kind of material the seals are made of; using the wrong formula of ATF will cause leaks as the seals may be incompatible with the composition of a particular ATF.
You will need the following items:
B&H # KAHDRGBRL Mfr # HDRGBRL CONVERTER $49.99
B&H # TEAV5RCA06 Mfr # AV-5RCA-06 component cables $9.95
B&H # HOHDMI301 Mfr # HDMI-301.5 HDMI CABLE $9.99
items found at this Web site:
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=770115&gclid=CJLlwdGunr4CFW4R7Aod5wMAQA&Q=&is=REG&A=details
rejetting your carbs is the key to matching exhaust you should follow the exhaust mfr instructions for jet sizes and consider having a pro do the carb work as jetting involves quite a bit of precison... mfr test their exhaust systems on dynos - their information can usually be trusted if they are a upper tier mfr..
1. get your mfr/model number from your kitchen range 2. logon to the mfr web site (Google it) 3. download & print it - or order it online, if the mfr supports hardcopy sales online.
A service manual is a very valuable tool, esp. with a bike of that age. Dealer, mfr. and clymer books are sources for that. Meantime, the public library may have your info in the 646 stacks of reference section.
Not sure about 2nd plug. If its wired, then its to insure you get ignition in the cylinder. Some mfr's did that for a while.
A service manual is a valuable tool with an aging bike. I suggest the
dealer/mfr. or Clymer books. In the meantime, go to the library
reference section
reference section...646 stacks should have what you need.
