Question about RIM BlackBerry ® 8830 Cellular Phone
The speedball wont move to the left
It moves freeely everywhere but left
    President:
  • 625 Answers
This is usally caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Posted on Aug 03, 2009
    Scholar:
  • 55 Answers
Your trackball is damaged you need to get a replacement for it or you can pop it out and see if anything is just shifted out of place in that case you can just shift it back into place and carefully put it back in and then it should work just fine.
Kyle
Posted on Jul 10, 2009
Wont start n wont move just dies there whats happening?
it could be a number of things,take it to someone that knows motors and can test it
Jul 16, 2015 | 1993 Pontiac Sunbird
Steering wheel wont move right or left engine wont move don't want to force it
inboard or outboard motor ??
unbolt the steering cable from the steering point of the engine or leg unit , then try turning the wheel and if it moves then try moving the engine or leg unit and see if it moves !?
Mar 27, 2015 | Boating
Windshield wipers
If the wipers move freeely by hand and it feels unhooked it is the linkage. if they feel tight like they are still hooked to the motor then the gearbox or circuit board went bad. for either one you will have to remove the motor.Be careful of the ground strap if there is one. Three bolts hold it on under the hood. with the motor removed you can remove the spindles and if there are any plastic grommets that are worn replacements are available at the auto parts. be sure to use white lithium grease as they are plastic. If a wiper motor is suspect i would replace it as windshield wipers are very important and nothing to skimp on.
Jun 18, 2013 | 1994 Dodge Dakota Club Cab
Using Windows 7.(Lost Desktop Icon).
Click the mouse "down" onto the "nearby" icon, and then "drag" that icon to move it somewhere a few inches away. The "missing" icon may now become visible.
Or, if you have used "auto-arrange desktop icons", look everywhere on your desktop for the "new" location of the icon.
Jan 02, 2010 | HP Computers & Internet
Belt slipping off of pully on maytag neptune mah5500bww
I loosed the moter and the belt is staying on. However, my belt is cutting the tub when the belt is moving off the pully.
Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
2001 Hyundai Elantra Windshield Wipers wont work.
give the mottor a few taps and spray wd40 in it if you can it releases things thats stuck. also make sure all movable parts are moving freeely. sounds silly but can catch on things. cables are not squashed and the like.
Mar 26, 2009 | 2001 Hyundai Elantra
Paper will not feed via ADF in Canon laser class 510 fax. keeps saying reset document when we try to fax or copy using either ADF or scanner. Briefly received error E337 (or could have been E377).
there is probably something in the paper path, double check and make sure no piece of paper is in it.
there is a small lever in the adf this is the sensor it should be able to move freeely and have a spring action, is it stuck?
are the guides set, and set to Letter?
Aug 26, 2008 | Office Equipment & Supplies
The touch focus
Will the red align in all 4 directions in the other areas of the screen? If it moves in all 4 directions everywhere but one section its probaly a resistor near your convergence amplifiers. If the red wont move in all 4 directions anywhere, then its your Convergence amp ICs faulty. Cost about 20.00. Hope this helps.
Jan 12, 2008 | Toshiba 42H81 42" Rear Projection...
RIM BlackBerry ® 8830 Cellular Phone Logo
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
