Question about Philips 50PFP5332D 50 in. Plasma Television
Blinking power and opc leds on front of unit
Have Sharp LC-37SB24U and was working fine for a month. Try to turn on and power and opc leds start blinking and tv does not work. Looks like some tpye of fault code: power blinks twice and opc blinks five times, 25? Then repeats again and again until I unplug the unit. Anyone got any ideas?
Thanks,
wine1959
  • 41 Answers
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Posted on Feb 25, 2010
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
I have a Sharp lc-46d62u and it blinking when i power it up the power led and the opc led blink twice a second the the opc led blinks and repeats. I read on this site that it may be the power supply so i...
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)...
Nov 01, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Word.
Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Tv shutting off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Dec 02, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Philips 50PFP5332D 50 in. Plasma Television Logo
423 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
