Question about Ultra Products 4-Port USB Hub
4 Port USB 2.0 Smart Hub Pro with Power Supply Part No. 42999
Dear Sirs
I´m using, since 2007, this Lindy 4 port USB 2.0 HUB connecting throught 2X 5m USB Extension - Active Extension Cables USB 2.0 (part no. 42915) , a VAIO PC to several devices (2 high resolution CCD cameras, one microprocessor linked throught one USB/RS232 converter and another connection to the comand of a DC motor).
Now I decided to change the DC motor command for a stepper motor command for better accuracy.
This one is commanded throught this microprocessor:
- CPU: Atmel AT91SAM7X256
- Power feed - 12V DC
- Connection to the PC - USB 2.0
This works pretty well when directly connected to the PC, without the HUB and the extension cables.
Nevertheless, when connected throught the Lindy active cables and HUB, in spite of the ATMEL CPU being aknowledged and its driver installed with Windows XP (and with no other device connected, neither the cameras neither the other microprocessor) there is no feedback from the motor position and it doesn,t works.
Could it be caused by electric noise interferences?
How can I solve this problem?
Best Regards,
José Cardoso Moura
  • Ultra Products Master
  • 787 Answers
Slap a voltmeter on the Power Supply for the USB Hub and make sure it is still working. It really sounds like what happens when you connect a device to a unpowered hub that is not capable supplying enough power.
Posted on Feb 28, 2017
Apple mobile device usb drivers has malfunctioned and exceed the power limits of its hub port.
Ewwwwwww... no fun.
You should try a "POWERED"
4 Port USB 3.0 Hub It's important that it's a "POWERED HUB" because you need the HUB to supply it's OWN power and not depend on your Apple E to provide power to your connected USB devices!
The good news is they don't cost much: $8 on eBay
Auction: 202096902632
Note that they include the power supply! Many other HUBS don't.
Your HUB is even LESS if you pick on the USB 2.0. Version, AND YES, each HUB MUST have it's own power supply and that's just what YOU need.
The ONE thing I didn't like about this HUB is the LED lights that are provided for each port! They are TOO bright so I opened it up and plucked all but one LED out. I also bought the 8 and 10 Port HUB versions and 'fixed' them too.
I also didn't need the switches to confuse things (accidentally turn one or more ports OFF)... so my trusty hot glue gun fixed that! All are constant ON now.
Anthony
Black 4 Port USB 3 0 Hub On Off Switches AC Power Adapter Cable For PC...
Oct 27, 2017 | Sony VAIO Computers & Internet
What's the voltage output from transformer
hi YOU CAN FIND THE SOLUTION FOR YOUR HUB
Warranty Period : Lifetime Warranty Integrated/Included Cable Length : 1.8m Belkin Pro Series USB Device Cable LED Indicators : 1 x Power LED (Green), 4 x Port Indicator LEDs (Green) Max. Load Per Port : 500mA Package Contents : USB 4-Port Hub, USB Device Cable (A-B), User Guide, Power Supply Power Supply Specifications : 5 V DC 4 A (Provided) Option to Expand/Cascade : Yes, via Hubs of this design (stackable) or other Enclosure Type : High-Impact Plastic Enclosure
Sep 27, 2010 | Belkin ExpressBus Networking Hub
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
4 port HUB is connected. My computer doesn't show it. Help! It is all plugged in with USB cable and when I go to MY COMPUTER it doesn't show.
The hubs usually show up in the hardware list and not as a seperate device. Only way to know it is there is to plug a usb device into it.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Sep 05, 2009 | CyberPower CPH420P 4-Port USB Hub
When i keep this hub pluged and try to reboot,
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives and devices (though not always)
Aug 22, 2009 | Targus Slimline USB External Floppy Drive...
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
My hard drive and midi controller wont work with usb
When you connect a hard drive and any other USB device to a 4 port hub you have to use the external power supply all the time. You may have fried the power pins on the USB port you used to connect the 4 port hub. If you can get the hard drive to work separately on the USB port, the 4 port hub may no longer be passing power from the laptop.
Nov 09, 2017 | Vestax Vci 100 Midi Controller
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Printer doesn't seem to like my 7 port USB hub
Hi Bob,
A lot of the time devices plugged into a USB hub don't receive enough power to run correctly. One possible solution is to get a dual-input usb cable and try using that. These cables connect to a usb device and then have two jacks for plugging into ports, which may supply enough power. You should be able to find them online fairly cheaply, so if you can spare 2 spots in the usb hub that may be your best bet.
Feb 14, 2008 | HP LaserJet 2200 Printer
Ultra Products  4-Port USB Hub Logo
439 people viewed this question
Top Ultra Products Computers & Internet Experts
Laxman Bisht
Laxman Bisht
John Hong
John Hong
David Payne
David Payne
Are you an Ultra Products Computer and Internet Expert? Answer questions, earn points and help others
