Question about Kenwood DDX-512 Car DVD Player
The unit seems to be to big to fit into F250 Space
All wiring is good but i cant fit it into the space on my 2003 f250 what do i need to do?
    Problem Solver:
  • 6 Answers
You need to get an adaptor kit to install it.
Posted on Jun 08, 2009
Where is the soleniod located
ITS IN THE VALLEY OF ENGINE. ITS A BIG ROUND BLOCK AND HAS BIG HEAVY DUTY WIRES GOING AND COMING OFF IT.. HEADING DOWN. OR YOU CAN TRACE THE WIRE BACK UP TO IT..
Feb 09, 2014 | 2003 Ford F250 Super Duty Crew Cab
Stater stays engaged replaced solenoid, starter ,neg cable and battery
Okay....if you have removed and replaced, basically, your starter assmebly and associated parts, then it sounds like you may need to shim it. Also, there should have been a small piece of wire....about the diameter of a piece of hangar. This is used to space the gears from the starter to the flywheel.
Please ask questions and let me know what you have done before we get into the electrical part.
Jan 23, 2011 | 2003 Ford F250 Super Duty Crew Cab
Ford 2003, F250 Desel, 7.3 Liter Head lights
first thing i would check is the wiring were the plow wiring is spliced in at this is most likly the culprate. or you may have a bad multi function switch in the steering column
Jan 02, 2010 | 2003 Ford F250 Super Duty Crew Cab
Need color code 2003 f250 for radio
Hi and welcome to FixYa,
On 2003 Ford F250 trucks we have worked on, the below wire color scheme is used. Of course it would be to your advantage to perform a voltage check on the wires on OFF and ACC condition of the ignition switch. Further, continuity of the speaker through the speaker wires would also help.
Good luck and thank you for asking FixYa.
Dec 28, 2009 | Car Audio & Video
I have a 2003 f250 6.0. big oil leak
Either the rear intake gasket is leaking,or the oil sending unit.It sounds more like a oil sending unit.It will have one wire going to it.It will most likely have oil all over it,and around it.With the amount of oil you are talking 275877.jpg,it would almost have to 833439.jpg the problem.It would look similar to these.Please let us know if this helps.thank you.
Oct 25, 2009 | 2003 Ford F250 Super Duty Crew Cab
Rats ate my wires I need complete wire diagram for 2000 ford f250
Review in autozone.com (free register), there you can find 31 Wiring Diagrams about F250.
Good luck (remember rated this help).
Oct 15, 2009 | 2000 Ford F250 Super Duty Crew Cabs
4wd won't work on 2001 F250
somethig is unpluged from the trans or t-case. get lookin at all wires goin or comin from them. good luck.
Jul 18, 2009 | 2003 Ford F250 Super Duty Crew Cab
Spare tire mount on 1986 Sieraa Classic
I had a similar problem with an 88 F250. Measure the tire height with tire standing, then measure space between hitch and measure frame from same place.
If the space between the frame would allow the tire to fit without the hitch, you need a wider hitch. If your current hitch has room for the tire you are all set.
Usually a heavier class hitch will have wider mounting points, but be aware that access to put in bolts may require you to weld the hitch to the truck.
Jul 17, 2009 | 1989 GMC Sierra
Kenwood DDX-512 Car DVD Player Logo
93 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
