FixYa.com
Tags:
RCA D52W19 52 in. Rear Projection Television
RCA Projo troubles! (by 2 users)
By Perkins - usenet poster
I got three of the model # D52W19, chassis # ITC222
RCA 52" HDTV Projection T.V.'s in for repair. One
has the green CRT leaked, coolant gone everywhere,
mind you, not a lot, and the blue CRT drive pcb is bad.
it's warranty, & they recommend raplacing the whole
CRT assy, only $ 100 + approx. Got another one with
the rf broke off, & had to reconverge the whole screen.
The third one has the red CRT arking, causing shutdown.
These are store stock, & not even sold yet!
My question is: "Are these really that bad of a set"?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 06, 2008
the power is bad
Best Solution
posted on Aug 09, 2005
Helpful (85)
Kim1
Kim1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes.  They have replaced at least 4 customer sets that I know of due to
them failing within first 90 days and parts not being available, right
after the model was introduced.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
Yup that's how bad it is.  I hate those!!  Effects all plastic bodied
RCA projectors.  (ATC221, ITC222, one other as well.)
Watch there is slight differences in same service model numbers, one
has "B" in it is not same as ones without "B" in it.
Example:  x52W19BYX1 & x52W19YX1.
I now have collection of bad CRTs or coolant leakers CRT growing at
alarming rate from those plastic projectors.
Soon, I'll asking about one model that stubbornly shuts down in use
even all CRTs was replaced.  None was leaking anything and one had bad
spot intially.  Needed to do this because I can't balance them
according to service manual instructions without upsetting projector.
Now it shuts down with customer's picture standard settings but while
in custom picture settings, it shuts down.  By the way that's DTV307
chassis.  Very heavy and not a light box so must disassemble to
transport chassis (is a base!), another cursed chassis. But I'm glad
this one is not as common.  :)
As aside, another shoddies showed up in CTC203 as well, I don't mind
the glue thing but mute pin is not functional by design, micro raised
mute at same time as power off so get the "POP!" instead of raising
the mute signal then power off in sequence to prevent that "POP".  Not
in EEPROM,this is programmed in the micro and there's no bulletin for
that!
Cheers, Wizard
Solution #3
Not Rated (0)
pawa
Rating: 0%, 0 votes
In stock with CRT Leakage, Thomson may still have an R/A Procedure in place
for this situation. Thay have replaced these in-stock sets in the past for
the leakage problems.
Can you Help with these Projection Televisions problems?
tv will not come on
tv attempts to come on 3 times... Answer This...
d52w19 - A thrill a minute
Ok guys.. here we go... I have... Answer This...
power supply problem
How difficult is it to get this... Answer This...
rca d52w19 floor model flat...
when i turn my tv on theres... Answer This...
capacitor near H out
Where is the capacitor near the... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
