Question about HP Color LaserJet 2600n Printer
The black toner not work - HP Color LaserJet 2600n Printer
    Problem Solver:
  • 13 Answers
Buy more black toner from an office supply store and replace the cartrige in your machine
Posted on Jun 04, 2009
I have 5 machines Ricoh aficio 3235c showing a massage loading toner and then black toner is empty Althought the toner is full????
This is one possibility, but there are other solutions if this don't work.
The black toner is not set message is displayed. The black toner is not set message is displayed even though the black toner is set.
[Cause]
There is a problem with the BCU lift. The communication with the ID chip is faulty.
[Action]
Update the BCU software version to the latest version.
Apr 01, 2017 | Ricoh Aficio Office Equipment & Supplies
4 black lines at every print
Mostly black lines prints due to problem in the Black toner cartridge. remove the Black toner out and inspect the toner drum, whether are their any black patch on the toner drum. If it so there's a problem in the black toner. Replace a new black toner and check.
Jan 24, 2013 | HP LaserJet CP1215 Color Printer
Does the HP CM2320FXI work only with a black toner
Consult your user manual. Each printer is a little different.
Jul 24, 2012 | HP Laserjet CM2320fxi All-In-One Printer
Invalid New Toner Black
is it a genuine toner?
some printers will not work with certain "reman" toners.
Dec 10, 2008 | Samsung CLP-500N Laser Printer
Dell3100cn Replace black toner
I had the same problem. My solution was to replace the black developer unit. It works fine now!
Oct 26, 2008 | Dell 3100cn Laser Printer
Page is black
NO Try to remove the toner and insert it again and make sure the door is locked properly
Apr 22, 2008 | HP LaserJet 2840 Printer
Black toner
If you refilled black toner you must replace the chip also or if you buy cartridge return the cartridge!!!!
Jan 24, 2008 | Samsung CLP-550 Laser Printer
ADD TONER BLACK
If the toner is an original you should not have a problem unless the Developer unit is faulty. The developer unit mixes the toner with the dev. If the dev unit TD (Toner Density) sensor is not working then it will not add toner. Try the following.
  • Remove black drum unit
  • Remove Black Developer unit
  • Tap the develop unit and shake side to side 5-6 times
  • Reinstall both units close covers and open toner cover
  • wait 15 seconds then close the cover
Hopefully then you will add toner if not the likely thing is that the developer unit will need replacing.
Hope this helps
Thanks J
Jan 15, 2008 | Ricoh Aficio AP3800C Laser Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
HP Color LaserJet 2600n Printer Logo
99 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
