Question about Garmin nuvi 205W GPS Receiver
My garmin says loading maps and doesnt go past that screen
jonniewalker
  • 1029 Answers
SOURCE: how to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Posted on Nov 23, 2008
  • 30 Answers
SOURCE: Garmin nuvi 250
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
GarminJunkie
  • 50 Answers
SOURCE: My Garmin shuts off in the loading maps screen
first I would try to load the current firmware from garmins website. if that doesnt work then try a master reset by holding the bottom right corner of the screen, holding that and turning it on. it will however erase all user data.
Posted on Aug 15, 2009
  • 1111 Answers
SOURCE: Garmin Nuvi 250W stuck on "Loading Maps..." screen
Try the reset, and if that fails, download the web updater from the garmin site and try that route.
Master reset will erase all way points or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
Bill 39c203c.gif Learn from your failures or you will fail to learn.  Theory: you understand why it should work but it doesn't
Practice: it works but you have no idea how
   ALL That is necessary for the Triumph Of evil is That good men do nothing.
Posted on Aug 30, 2009
sharcnet
  • 2130 Answers
SOURCE: my garmin nuvi 260 will not go past the loading maps screen
There is a corrupt or missing file associated with the mapping thats causing it to lock up. When that file is missing, your Nuvi never gets to the routine for communicating with your PC. That's why your PC can't detect it.
I've fixed this problem before. The unit must be placed in PRE-BOOT mode, forcing Windows to recognize it and then using a specific program, reflash the firmware to an older version that doesn't care that the file is missing. The unit will then boot properly and you'll regain detection to the unit in Windows. Then you can repair/replace the missing files and then reflash back to the latest firmware.
Yes, its a pain and not an easy process to the novice.
- Jim
SHARCNET-USA
Posted on Sep 03, 2009
My garmin wont go past the loading maps screen and if it does the touch screen wont work please help
Mine is doing the same thing. My Garmin is just about 1 year old now. Wonder if the battery is bad, although I plug it into the power port on my truck only when I'm going to use it.
Nov 18, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Upon turning my Garmin Nuvi 1300 on it sticks on the screen that says "GARMIN".......Loading Maps. It never goes past this screen. I have had this unit since the end of December. It is fully charged and I...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Apr 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
My sat nav 1300 won't get past 'loading maps'
IT WILL STILL BE UNDER WARRANTY BUT TRY A SOFTWARE DOWN LOAD FROM WWW.GARMIN.COM THEN TAKE IT BACK TO THE SELLER
Dec 18, 2009 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 260 will not go past the loading maps screen
- Jim
SHARCNET-USA
Sep 02, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin shuts off in the loading maps screen every time we try to turn it on. It will flash the Garmin logo when it gets turned on, go to the loading maps stage and then just shut off. Any ideas?
Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
My nuvi 265w is freezing up or will not boot up past the Loading Maps screen.....boot
remove your SD card from the device and see if it passes boot screen and tells you that you have no maps
in that case your SD card is dead and you need to obtain new maps from garmin
if it still looks bad regarding booting - your device is faulty - so if still under warranty - send it to service
Jul 31, 2009 | Garmin GPS
Cant view map on gps
When you go past 4gigs on a micro SD card it becomes HC (high capacity I believe) and will not work with most Garmins. The 2 gig's the limit.
Dec 11, 2008 | Garmin Rino 530 GPS Receiver
New GARMIN 660 Won't get past the Intro screen
Problem solved: I got through to Tech Support. They suggested a 'hard reset', which solved the problem: Put you finger on the lower right screen while you power up and it will do a hard reset---and it will get past the "loading maps" screen, where it had been stuck.
Dec 25, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
219 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
