Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Need to change kenmore from Lp to Ng
I have the orifices... But I need to know how many turns for the 2 oven adjustments.
  • 999 Answers
Without a device to measure the pressure from the orifice you will have to adjust for the best flame on the burners (blue with no yellow) not going beyond the spreader plate.
Eric
Posted on Jun 20, 2009
Need to convert from lp to ng on a kenmore 362.7556191
conversion should be done by a qualified tech. you need ng orifices to replace the top lp orifices on top burners, you need to turn top of regulator over to ng, this is located behind bottom door and you need to adjust your orifices in your oven burner back up, should be screwed complerely down now and same for broiler also air adjustment may be needed. do not recommend you try this yourself
Feb 05, 2010 | Kitchen Ranges
With the Jenn-Air PRG4810NP (Natural Gas), is there any way this can be converted to LP with a regulator? I'm not sure if I ordered the regulator for the LP range and attached it to the NG model, if this...
Conversion is usually accomplished by flipping the regulator cap around. Nat side is hollow and LP is solid to hold the regulator open. The oven orifices are adjustable and the surface burnres can be either adjustable or have LP replacements.
Eric
Jul 01, 2009 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Whirlpool SF325 Gas Kitchen Range
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Nov 18, 2007 | Kitchen Ranges
Converting Kenmore gas range to LP???
I just converted mine and the regulator plug was not the same as the one in the manual. It had a black plastic piece snapped into the cap that had to be turned over for LP. I unsnapped it and turned it over. I changed the nipples for the burners and they worked great. The oven orifice had to be turned all the way down (clockwise) ans the air damper opened.
When I did all this the oven still had a large yellow and blue flame. I raised the oven orifice up 2 turns and then turned it down all the way and the oven flame was perfect! The oven orifice is hard to turn so make sure that you turn it all the way down using a 1/2 inch wrench.
Sep 30, 2007 | Kitchen Ranges
Flames in oven are WAY too high! Having trouble lowering them.
Did you change the orifice in the regulator? The orifice opening for LP is a different diameter than the opening for Natural Gas. If you've already attempted changing the settings from Natural to LP, you may want to double check the orifice under the regulator cap, or...you may have a regulator problem. You will need to turn the gas off prior to attempting this. The regulator will be located in the back of the oven somewhere near where the gas line connects to the stove. There is a gas orifice that needs to be turned over to change gas settings. "LP" should be present if it is set correctly. Let me know if this helps.
Jul 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Apr 08, 2007 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
150 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
