Question about RCA 32F531T 32" TV
Tv won't turn on
I tried to turn my tv on this morning and it wouldn't come on. there isn't a reset button to my knowledge.  i turned the cable off and then back on but it didn't help. can you help
  • 7 more comments
  • Anonymous Nov 02, 2007
    i cant turn my tv on
  • Anonymous Dec 09, 2007
    While watching tv, it went to a blank screen the power was on and the light was red, but could not get a picture. Unplugged the TV and tried various other things and it still will not work.
  • rosieroyal Dec 15, 2007
    tv remote does not work; how to unlock my tv
  • Anonymous Dec 26, 2007
    TV will not power up. Tried switching plug. Remote batteries, etc.
  • Haireball Dec 27, 2007
    Our RCA 32" tru flat just wont turn on anymore. It worked fine last night and this morning it turned on then shut itself off and now it wont turn on at all. PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
  • kclay Dec 27, 2007
    The TV was on and then all of a sudden, there was no picture while watching the game. I turned it on and off and still nothing. This happened on December 25, 2007. What in the world?
    Please help!
    Regards,
    Clay
  • Efountain Jan 03, 2008
    Have a RCA 32 True Flat, it is 2 years old and about 3 months ago it kept shutting itself off. I unplugged and reset and it worked fine until last nite. It just will not stay on. Is this a common problem with the Type.
    Any help would be grateful!
    Thanks-E
  • Suebug Jan 09, 2008
    Turned my TV off last night with the remote, tried to turn it on today and it will not come back on. I used this sight to fix the same TV 3 weeks ago but I am not finding the same advice.Somethng like hold the code search then enter ,then TV, must not remember right cos it won't come back on.What I haven't found either is how to unlock my TV it's a 27" RCA 2005. A friend messed with it and it said it is locked, could not use the controls on the TV just on the remote.
  • Anonymous Feb 29, 2008
    rca television troubleshooting clicks four time and doesnt turn on
jlwash48@hotmail.com
Posted on Feb 26, 2008
I got same problem.
Posted on Jan 30, 2008
    Genius:
  • 1,694 Answers
Please verify model number and give service number.....T.
Posted on Oct 25, 2007
2 Suggested Answers
  • 1694 Answers
SOURCE: tv won't turn on
Probable bad flyback transformer = shop repair....Do you want
part # 's....? Please provide service number from back of set..
Posted on Dec 08, 2007
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
2005 Honda VT 750 Shadow Aero will not turn over
Hi, James before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2000 Honda Shadow Ace 750 Wont Start Turn over at all
What to do When Your Motorcycle Won Start
Honda VT750C2 Shadow Spirit Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C2 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 01, 2017 | 2005 Honda VT 750 Shadow Aero
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
For the past 2 weeks, when I try to start my 2003 Nissan Xterra, it seems sluggish, but the engine will turn over. On 2 separate occasions, when attempting to start the engine, it wouldn't turn over ...
Checked Cables how?
Looking & Touching isn't doing anything
You have to do a voltage drop test or remove
& clean the ends. I would do both
Remove the starter & have it tested at parts store,
assuming you don't know how to do a voltage or
current test while cranking.
May 24, 2011 | 2003 Nissan Xterra
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
Tv won't turn on
Nov 16, 2007 | RCA 32V550T 32" TV
RCA 32F531T 32" TV Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
