Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP Logo
Posted on Jun 04, 2009
Hayward SuperPump2 1.5 hp with EC 75 filter?
Is Hayward SuperPump2 1.5 hp uprated a good fit for Hayward EC 75 Perflex DE filter? I/G pool, appx 40K gallons. Thanks
Anonymous
Level 1:
  • Contributor 15 Answers
  • Posted on Jun 23, 2009
Anonymous
Contributor
Level 1:
Answers
15
Questions
0
Helped
18542
Points
38
Should be a good fit looking at the specs
My Haward perflex EC-40 filter allows DE and dirt back into the pool whenever we start it up or vacuum.
There's a hole in the filter allowing DE and dirt to pass. Find hole and repair or buy new. I just bought new grids off of ebay, great deal. I payed $112 for complete set by Unicel and saved over $100 My filter is a Hayward DE4820
I presently have a Hayward EC 60 (yes 60) pool filter and a 1 horse power motor.. It works well but it does not support the new Pool Vac cleaning robot I purchased. It supported my old Pool Vac, but not...
if you buy an adaptor,should be a 1 1/2" dia hole,in the bottom of the skimmer, put it in the skimmer hole,put your vac line on that, turn the valve to it's on full skimmer, it will work,
thats a nice filter,pool guys will sell you anything!
esp at this time of year!
buy the minumum!
2helpful
Instructions for putting Hayward Model EC-75 filter on pump for a inground pool
Here is a copy of the users manual for these pool filters. It should give you detailed instructions about installing the Hayward Perflex.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Hayward Perflex EC-75. The DE is gumming up after about 1 week all up in the fingers. Keep taking the filter apart and washing it down then replace the DE but only getting one week out of the new...
I maintain three commercial pools ... one a hot tub. We replaced the DE with sand filters this spring. The last year of DE - even with insisting the patrons shower first, we only got one week out of the DE ... and we were dumping the water also. Suntan oil, body oils ... it was a mess. The water was sparlking for 6 of the 7 days ... The only way to keep it that way was dump the water and change the DE.
Maybe your filter is not big enough. Had you given the gallons or the size of your pool, I would have calculated the filter area for you. If you can post it and if FixYa, notifies me, I would be glad to do the calculation.
1helpful
I bought a used Hayward Perflex Extended Cycle DE Filter Model#EC45 I have to keep backwashing it, it flows heavily back in the return but it only flows good for a little while. What do I need to do? It...
Here is a link to the hayward manual. Be sure to follow the pre-coating insturctions carefully.
Use only the swimming pool grades of
diatomite, such as:
CELATOM . . . . . . . . . . . Eagle-Picher Industries, Inc.
AQUA-CEL . . . . . . . . . . Johns-Manville Products Corporation
DICALITE 4200 . . . . . . . Grefco, Inc.
WITCO . . . . . . . . . . . . . Witco Corporation
The EC-50 filter uses a 5 lb. (2.3 kgs.) charge of diatomite (D.E.)
Here is a link to the hayward manual for a EC-50 I think its almost the same as the EC-45
http://www.haywardnet.com/products/manuals/pdfs/manual10.pdf
Water leaking out the top
Here is a copy of the users manual for these pool filters. It has detailed illustrations about how the filter should be put together.
Have a model # EC-45 Hayward Perflex ,combine unit with pump can you tell me of any mantiance that might have to be done to this filter set , seems this year useing alot of DE dirt to get pool clean, when...
YOU HAVE A BAD GRID-GRIDS IN YOUR FILTER. TAKE THEM OUT AND FIND OUT WITCH ONE IS BAD . DO THIS IN THE SHADE DIRECT SUN KILLS THESE GRIDS.. WELCOME TO THE HAYWARD NORTHSTAR .. REMEMBER TO VOTE OR COMMENT .. IT IS THE FUEL TO KEEP ME TRYING TO HELP U GUYS .. JAY
Water and de backflo into motor from filter
Try checking the users manual. I don't have an exact answer for you, unfortunately, but the users manual for these pool filters is comprehensive and has diagrams. Hopefully, you can find your answer there.
We have aEC-65 hayward pool filter with a 1HP motor why does the pump slow down run at higher pressure ?
I believe that this particular model is a DE pool filter. Is that correct? If you are operating with a media other than DE, let me know. Assuming that you ARE using DE:
1. You DE could be coated to the maximum with pool dirt algae, etc. To correc this problem, you need to bump the filter.
2. You could have an overcharge of DE. To remedy,
Bump-Drain-Recharge.
3. Restriction in return line caused by small
eyeball fitting. To correct, change to a larger sized fitting.
4. You could have a partial closed valve on a return line. You will just need to open the valve.
5. Make sure that your pump strainer basket and pool skimmer basket are not clogged.
6. Make sure that your pump impeller valves are not clogged.
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
