Question about IBM ThinkPad T30 2366 Notebook
T30 with XP hangs and freezes intermittenly during usage...
I tried reinstalling the operating system and installing a new hard didn't matter. I run service pack two it freezes at the end of it. I restart it freezes while loading the system services on startup, also when I open an application and even plug my usb mouse just keeps happening. I ran chkdsk on all three hard drives I had and it found nothing...I'm a little frustrated so if it sounds like I'm babbling I'm sorry, help!!! I know you all that the memory slots are a common problem with these t30's but I have never had a problem getting into windows it's just having windows remain responsive is what the problem is...thanks in advance!
  • shaftfx Oct 25, 2007
    Ok I removed one of the memory slots and so far it has worked without freezing, thanks. Hopefully it'll stay that way. :-)
  • 181 Answers
There's a chance it's still the memory slots. You know, they are located directly beneath the hard drive.
Just a thought.
good luck
Posted on Oct 25, 2007
How do I erase my hard drive on a IBM T30 and reload the operating system and drivers.
Get an install disk for the operating system you wish to install (Make sure your computer is able to handle that operating system first), then put the disk in and boot to the disk. If your computer is not set up to boot to disk first then you will have to go into the BIOS, usually F2 of F12 on boot (whatever says press to enter setup), then change the boot settings from there.
Once you are inside the installer for that Operating System, it will give you an option to erase the hard drive you are wanting to install the operating system on, and restart new. Just so you are aware, this will reformat and ERASE EVERYTHING on that hard drive, so make sure that you have anything you want saved backed up somewhere else.
Once that is done, continue installing the operating system and then your hard drive will be erased, and the operating system will be reinstalled.
If you were just looking to erase a hard drive, then you can go to my computer, then right-click the hard drive you want to erase, then click format. THIS WILL ERASE EVERYTHING!
Hope this helps!
Mar 23, 2011 | IBM ThinkPad T30 2366 Notebook
I use a HP Compaq nc6220 laptop, with Windows XP Pro, Version 2002, SP3, Intel Pentium M 1.73 GHz Processor & 1GB RAM. My computer just freezes/hangs after it boots. At times I am able to use it for...
When it hangs if you wait does it come back to life again?
I'd strongly reccomend installing a new operating system, maybe on a different drive to save your current one, and see if it still hangs on that.
I've had this issue with countless pc's, unfortunately I've always gone through my usual processes and fixed it without ever knowing (or caring) why it happened in the first place. But I'd start with a new installation of the operating system on a different hard drive as the first step in your diagnosis for sure. I'd also say its very likely that will fix it anyway, and if it doesnt then its a hardware issue of some kind (can be diagnosed further to find out exactly what)
Oct 29, 2010 | HP Compaq nc6220 Notebook
On the mini 1000 - tried to install Windows xp (tried Vista and 2000 also) after a system crash. Since there is no dvd/cd drive I used an external drive with a usb interface. It starts to install and then...
Hi, you need to ensure your hard drive is set up correctly! To install XP first press the F1 key during bootup, select the primary boot device (your external drive) in BIOS, save changes and reboot, allow files to be installed, but when finished, select delete operating system, partion hard drive and reformat, allow system to reboot, then commence new installation of XP. If your problem persists it is most likely a bad section on your hard drive, and will need replacing.
Hope this helps
Jul 16, 2010 | Computers & Internet
The system hang during winxp install
If its hanging during install you need to turn virus protection off in the bios. Have a root around in the bios and you'll see it sooner or later, If you need further help just shout.
May 23, 2009 | Acer Computers & Internet
XP Pro not installing from CD
Check the cable that connects to the hard disk. It seems it doesnt "see the hard drive". Try to see in the bios if the hard drive was detected.
Jan 11, 2009 | Computers & Internet
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
HDD Reformatting
why not reinstall sp3 again for windows xp if it freezes then it might be looking for files that don't exist anymore. If the virus attatched itself to your files they may have been removed when you ran your virus software. you don't need to format to reload windows. Just simply do a clean reinstall on C drive.
Oct 23, 2008 | Microsoft Windows XP Professional With...
IBM ThinkPad T30 2367
I bet your hard drive crashed on you. You might have to buy yourself a new hard drive and replace your old one with it. Then format it and install a fresh copy of your Operating System on it. Your error condes here indicate to me that you either got a blue screen or similar. Blue Screens and/or the code that you stated here are usually caused by a software issue, and are rarely hardware issues. But in this case, you may have gotten something bad on your computer, such as a virus or serious spyware, that wiped out your Operating System And caused your hard drive to crash/become corrupt. As I mentioned, try replacing your hard drive. Hope this helps.
Sep 07, 2008 | IBM ThinkPad T30 2366 Notebook
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
ok here it is it is a auto repair sys from lenovo
This page has automated features! You can use the automated features on this page by installing a special, free plug-in. This one-time installation will not affect your computer's performance or compromise your privacy or security. fw.gif Install the automated content plug-in
chat.gif Just relax and let Lenovo Experts Live do it for you. Buy it now! New!
Some of these steps may not apply to your computer. Test for system startup after performing each step.
Select your symptom from the following list or continue to the Need more help? section:
Mar 24, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
387 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
