Question about Xerox Office Equipment & Supplies
After turning my copier on a motor runs for some time before it will copy. That warm-up time got to be longer and longer. Now it refuses to copy.
  • dechom Jun 04, 2009
    Not very helpful. It said that I should get Xerox involved.
    That is not an answer to the problem. It only says that I should ask someone who can solve the problem.
    Dean Echols
    Top Expert:
  • Xerox Master
  • 76,846 Answers
U are going to have to get Xerox support involved in this problem, the fact it takes longer and longer to load indicated a parts wear issue, most likely the copier toner loading mechanism.
Posted on Jun 04, 2009
Starter motor on c240 auto starts at times if like battery is flat u keep turning the key it then eventually starts no noise from starter motor or any thing and when it does start it starts perfectly
your starter is peobably going out brushes or solenoids wear out over time sounds like brushes inside the starter to me replace your starter
Jul 04, 2012 | Hyundai Cars & Trucks
How do you fix a dead hard drive?
The drive has failed but it may be an internal (motor, Read arm) or external (electronic controller) fault, if it is external you can find a circuit board off another drive the same model and fit it to your one to get it going, if it's internal there's not a lot you can do, there are data retrieval companies but they charge a lot to get the data back as they use specialized expensive equipment to get the data back.
One thing that sometimes allows short (30 mins or so) run times is put the drive in a plastic bag, Put it in the freezer overnight. then try it and copy the files off as quickly as you can.
Mar 08, 2012 | Computers & Internet
WE HAVE A LANIER AC122L COPY MACHINE AND IT TAKE IT FOREVER TO WARM UP TO COPY AND ON THE COPIERS LEFT SIDE WHERE IT VENTS, THE VENT IS COVERED WITH BLACK FROM WHAT WE THOUGHT WAS THE CARTRIDGE BUT WE TOOK...
THese machines run really dirty. Has it been a while since it was last serviced? In addition to it starting slow, are the copies starting to come out light? Sounds like its getting time for a pm. How many copies are on this machine?
Jan 20, 2011 | Office Equipment & Supplies
Aficio 551 - error code SC124
Definition- [B]
No encoder signal from the scanner motor
-Possible cause-
• Scanner motor connector defective
• Scanner motor defective
• MCU defective
• Scanner wire, timing belt, pulley out of position
• PSU defective
The screws of the pulley usually are cut that moves the scanner this causes that the car is crossed and that the sensor does not detect the home position. check and corect this defect.
Mar 03, 2009 | Ricoh Aficio 450 Copier
Heater blower problem
under the hood of the car on the passenger side you will see a round motor sticking up.thats the blower motor there should be 3 screws holding it in place and one plug to unplug.you lift the old motor out and put the new one in in its place
Jan 13, 2009 | 2002 Hyundai XG350
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Longer warm up time accompanied by a loud grinding noise
There are few gears inside the copier that probably need to be replaced causing the grind and the copy quality to happen. It wasn't looked at by the engineer at the time because it happened after they left. They should come back in to fix it.
Aug 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp-275 Not a simple paper jam
This sounds like you may have a bad jam detect sensor, there is a sensor on the exit end of the fuser on the right and the flag for this is located in the middle of the exit guide on the fuser this gives us most of those types of jams.
Hope that helps...
Jun 16, 2008 | Sharp AR-275 Copier
Solution
i thick the copy lamp is flickering it can be solved by clening white reference in platen glass if still persists press ash,interupt,c,interupt and enter 14 then press green colred start key.
Mar 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
19 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
