Question about KWorld (KW-L883D) (KWL883D) Video Capture
No sound when playing video with kworld dvd maker
I have a kworld dvd maker usb2.0. I am trying to capture from a video recorder. I have picture but no sound-what is the problem. I am not a techi so please reply in idiot language.
Powerdirector 10 script installer error cannot create file??
Try to install on a different PC. Also, ensure you have the latest Microsoft updates and service pack. Contact KWorld for support and possible newer compatable software download from their website.
Nov 16, 2013 | KWorld Xpert DVD Maker USB 2.0...
How do I get vhs video onto my computer?
You need a TV capture card... the package includes connectors for VHS & other DV cameras, you also need of course a VHS player..
While the VHS player is playing your VHS tape... the computer can now record it via the TV capture card.
That's what I do... goodluck and don't forget to rate...
Feb 01, 2011 | KWorld DVD MAKER USB 2.0 (660448660114)
KWorld USB2800d audio quality
Your computer's sound card maybe at fault
May 03, 2010 | KWorld Xpert DVD Maker USB (vs-usb2800)...
No sound in kword dvd maker when doing video capture
if using Windows make sure to check the Sounds and Audio device Properties by Right clicking the speaker icon on the right side of taskbar. Check all tabs for Recording settings, there may be recording tests on some pages...check Advanced rbuttons for recording settings.
note settings prior to modification so you can change them back if needed.
Dec 31, 2009 | KWorld USB DVD Maker Xpert DVD Maker USB...
Black and white and no sound!
You are trying to copy or record a copy protected video or your VCR has internal copy prevention turned on. If you wish to copy tapes or dvd's, use a PC based system. You can also pull the raw video information off the VCR if you know where to connect to on the video board of the VCR. I cannot tell you how to to this as I have no idea which VCR you are using however, google the brand and model of your VCR, find a schematic and you should be able to pick the raw video feed into the video decoder chip and use that. Use shielded cables and NEVER undertake any work inside anything when it is plugged into the power outlet, disconnect it first by removing the plug from the outlet (never rely on the switch either).
Dec 12, 2009 | KWorld DVD MAKER USB 2.0 (660448660114)
I am trying to import video from a Canon ES75 Hi-8 camcorder. I've trying to use DVD Maker USB 2.0 from KWorld. My laptop is an HP Pavilion C700 with a 1.73 Mhz CPU, 1 GB of RAM, and 25 GBs free drive...
" No signal is detected by the software."
In older models of Hi-8 cameras the s-video out must be enabled or the camera switched to playback mode  to get signal. Check that.
Nov 25, 2009 | KWorld Xpert DVD Maker USB 2.0...
I need the drive for Kworld usb2800
Try:
http://us.kworld-global.com/main/support_down.aspx?mnuid=1312&modid=21
Mar 18, 2009 | KWorld Xpert DVD Maker USB (vs-usb2800)...
GOOD VIDEO BUT NO SOUND
try to configure it to your control panel in the computer. it must be the problem hope that helps!
CHARCOIS
Aug 03, 2008 | KWorld (KW-L883D) (KWL883D) Video Capture
Windows Movie Maker
A lot of times Dazzle provides a calibration program for video and sound. See if you can run that.
There usually is a seperate audio capture control. If you go to your sound mixer and check the recording settings, is the audio capture from the Dazzle selected?
Jun 08, 2008 | Pinnacle Dazzle DVD Recorder
Sound is not recorded
The problem would appear to be your audio settings.
You have the audio input set to Realtek HD Audio Input. That is the audio input on your soundcard, not the video capture card. You will need to change this so that you have the capture card selected. (I am not familiar with this exact model of card so I can't tell you exactly what it will be called.)
Alternatively, if you are trying to capture the audio via your soundcard (not recommended as it can cause sync problems) you will need to make sure that the 'line in' channel in enabled in the Windows mixer:
Start>Control Panel>Sounds & Audio Devices>Audio Tab>Click Volume in sound recording section>Tick Line In
Hope this helps,
Matt
Mar 06, 2008 | KWorld V-Stream Xpert VS-L883D...
KWorld (KW-L883D) (KWL883D) Video Capture Logo
1,092 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Oluwadamilola Adu
Oluwadamilola Adu
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
