Question about Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator
Hotpoint model#CTX14AYBBRWW FREEZER WORKING FINE. FREIG IS NOT WORKING AT ALL. WHAT DO YOU RECOMMEND?
3 Suggested Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: RAFIK02UK@YAHOO.CO.UK
MANY THANKS
Posted on Mar 01, 2010
heatman101
  • 43501 Answers
SOURCE: fan works but not getting cold enough top freezer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
Jan 30, 2014 | Hotpoint RFA51 Bottom Freezer Refrigerator
Fan works but not getting cold enough top freezer and the bootm freige
heatman101
Oct 07, 2010 | Amana ATB1832AR Top Freezer Refrigerator
I HAVE A HOTPOINT REFRIGERATOR AND LATELY IT DOES NOT GET COLD ALTHOUGT THE TOP FREEZER IS FINE I TOOK THE THE REAR PANEL OFF INSIDE THE FREEZER AND IT WAS FULL OF ICE WHAT CAN BE CAUSING THIS PROBLEM AND...
defrost your unit for about 2-3hrs..check the fan fan if the bushing has no wiggle, make sure the damper that control the air from top going to fridge is open..you can also check the timer of defroster if it is still working
Sep 13, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Myfreezer works fine but my fridge only works for about 15 days and then stops working,when i unplug the fridge and let it defrost the freezer will work for another 15 days it is a hotpoint ff4dx fridge...
This is telling you that you have an automatic defrost problem.
Before I go on here the model number you passed appears to be a UK model.
The problem can be:
1. The defrost timer / control
2. The 60 deg F defrost bi-metal thermostat
3. Wiring
4. The defrost element.
Some info about the 5 year warranty is on page 11 of the owners manual: http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19506810502_UK.pdf
I do not locate the appliance parts manual for this unit as I am not in the UK.
Thanks for using FixYa.
Kelly
Jun 16, 2010 | Refrigerators
Freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Icemaker making small amount of ice
I RESET THE SWITCH ON THE ICE MAKER AND TURNED THE TEMP TO 9 FROM 5 AND IT STARTED MAKING MORE ICE. I'M NOT SURE WHAT WAS WRONG BUT IT APPEARS TO WORKING FINE NOW.
Dec 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Oct 19, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Defrost not working and freezing up, fridge not cold. GE hotpoint model #HSS25IFMDWW
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Hotpoint Refrigerators
Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator Logo
85 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
