Computers & Internet Logo
A
Anonymous Posted on Jan 30, 2014
CAMTASIA 2 MAC
KEY
5answers
Need a product key for camtasia studio 8.0
You can download a free trial here, and if you like it, you can buy the code here too.
Capture Edit amp Share your ideas with the world using Camtasia Studio
Camasia 8 Recorder won't work on Windows 7
Delete 7 and 8 but then only reinstall 8 and see if that works because they might be screwing with each other.
Camtasia Studio 8 Only Opens Once per Start-up
what u need to do is if you have windows press ctrl shift esc and the task manager should pop up go to processes then on the list you would see Camtasia studio right click and select end process or if u see the name more than once end the process of them all the reason you have to do this is because for some reason the first time you open and close it it dos not actually completely close witch then gets in a glitchy state to where you can not open in again but by ending the process u should be able to open it again
1helpful
Dear Sir: I purchased snagit 10 on 5/14/2010 and just completly destroyed my computer by way of viruses. It completly destroyed my computer so i purchased a Apple imac. I was wondering if there is a...
Hi Robert
You cannot get snagit for a Mac, but you can difinitely get Camtasia which is very similar to Snagit and like Snagit its also a product of Techsmith.
You can look for Camtasia for Mac.by going to manufacturer site techsmith.com
Using Camtasia
You have 3 Audio source options when you record using Camtasia,
1) Speaker audio
2) line in
3) Microphone
You won't be able to record using line out.
1helpful
5answers
Camtasia video capture = black screen,
I will not be back to your service. Your 'smilemaker' expert was rude, succinct, had no idea how to solve the problem and gave me a bad taste in my mouth. I have since identified the problem to be one of Direct X variety which is not working correctly in the register.
Memory Problems
The clip can be recovered if you open the temporary directory where Camtasia stores the raw captures in AVI format. The path to the temporary directory can be found by opening the Camtasia Recorder > Tools > Options > Program > Temporary file folder (I'm using v.5 so it may be a little different in other versions).
I've found that there's a certain workflow that seems to work best and you can avoid accidentally erasing your temporary files and having to start your capture session over from the beginning...
  1. Stop Camtasia Recorder - Pressing the Stop button on the Recorder likely won't work, so open the Task Manager (CTRL+ALT+DELETE) and select "CamRecorder.exe" from the Processes tab and click "End Process". Don't open Camtasia Studio right away after doing this step - You'll likely be prompted to recover the recording and in my experience Camtasia hasn't done a very good job at being able to do this successfully and you may end up losing your temp files.
  2. Recover your raw capture files - Navigate to the path where Camtasia stores its Temp files (look above for instructions). Typically, there will be a folder titled "CamCapture{random string of numbers/letters}" - look for a folder with a date modified attribute of the date/time you were working on your project. In that folder, there will likely be several audio and video files as well as an XML data file. The video files will all be 1GB apiece as Camtasia splits the capture into chunks and then pieces them back together to create one continuous file. Cut and paste the files from this folder into a new location outside of the Temp directory. The most important one is the FileWriter{random string}.avi as this is the pieced together file - It will have the largest file size.
  3. Add your media files to the clip bin/timeline - Start a new Camtasia project and import the FileWriter{xxx}.avi clip into the Clip Bin and drag it onto the timeline. Now all of your video/audio should be recovered and available for you to edit. If you have particularly long clips, you may want to check how the audio syncs with the the video towards the end of the clip. If it's messed up at all, you may want to try adding the smaller, chunked recording segments sequentially onto the timeline to see if that helps. If the FileWrite{xxx}.avi clip is good though, you can delete all of the other smaller audio and video clips associated with the capture from your pc to save space - just keep the FileWriter{xxx}.avi clip - the XML can be deleted too.
Good luck - We've had the same trouble here and we use Camtasia almost everyday. In my experience, this seems to happen more frequently when we capture larger dimensions - especially if the capture contains full motion video (as opposed to just screen captures of a product demo or something) and we always seem to have trouble when capturing things that play back FLV or SWF clips at a higher bitrate. This issue is also described in TechSmith's Camtasia knowledge base.
Top TechSmith Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a TechSmith Computer and Internet Expert? Answer questions, earn points and help others
