Question about Brother ML-100 Typewriter
Trying to install ribbon and correction tape which goes first and how
  • 30 Answers
Hi there.
Lets start with ribbon ( the black plastic cassette). You need to place the cartridge on the carrier, engaging the back of the cartridge first.
Press the cartridge into place. Guide the ribbon between the print wheel and the paper path. Turn the drive wheel ( small blue or orange dial) in the direct of the arrows (counter clockwise) to take up any slack.
Here is the USER MANUAL page for you along with some pictures.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_ML_100_EN_216.PDF
Kind regards,
Duane ONeil
www.FJAProducts.com
800-982-9989
Posted on Jun 10, 2009
4 Suggested Answers
  • 3594 Answers
SOURCE: Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
Posted on May 20, 2008
FJA Products
  • 30 Answers
SOURCE: how to install correction tape and what one to buy?
Hello-
This is an easy fix. The items can be seen here:
http://www.fjaproducts.com/SearchMe/Department7782.asp
on the Genuine Smith Corona Box you will see a small installation guide.
If you need more assistance with the installation, just give us a call or drop us an email.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
  • 3594 Answers
SOURCE: i need to know how the correction tape goes onto
The full spool goes on the L.with the tines to the right. the L/O tape goes thru the black guide with the dull side facing the paper. between the the shinny pieces, thru the black guide on the right around the slacker wire and the take up spool last.
If you have a fax # I can send you a picture.
DickyO
Posted on Jun 22, 2009
How to install correctronic ribbon
Open top cover, small correction tape orange or yellow lift off is kind of tricky, left side goes on small spool holder feeding off the top and going around front of print wheel. by the way relaase the printwheel so it pivots back toward you, eaiser to see, correct tape goes in front of wheel and pivots very similar to left side. Correction tape has good side and bad side good side a matte finish should face away from you, this is the correction. Regular riboon just lifts up reom the front and snaps back in place. two little plastic tabs on back of ribbon case fits in two little holes in carrier. Hop this helps real hard to describe.just works...
Sep 29, 2013 | Brother Gx-8250 Correctronic Electronic...
How do I install a new correction ribbon?
the spool with the new tape goes on the left side of the carrier, with the teeth pointed in. then the tape goes in the guides in the back of the black ribbon plate, and behind the two metal fingers that stick up in front of the card holder. there is a flat spot on the far right and left of the ribbon plate, that the tape fits in., then just put the other spool (take up spool) on the post on the right side of the carrier. put the ribbon back on
Feb 22, 2011 | Brother GX-6750 Typewriter
How do you put in the correction tape in the brother A X--425
The correction tape feeds the same direction as the ribbon, andI think it only goes on 1 way. The tape goes in front of the ribbon.
Jan 25, 2011 | Brother ® Starter Kit for AX, GX, SX and...
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
I changed the correction tape on our IBM wheelwriter 3 and it doesn't seem to be lifting the error. Any advise? The correction tape is not old and I had already tried moving it a couple of inches but it...
You may have a very old correction tape or ribbon, a non correctable ribbon or it isn't properly installed
Go to LEXMARK.COM for a downloadable manual.
DickyO
Mar 31, 2010 | Lexmark Wheelwriter 3 Typewriter
Installed a corrective ribbon on a SL480 typewritter, now I can't get the ribbon back on.
Sounds like the correction tape is not installed properly. Try remving and reinstalling it again. Make sure the hammer solenoid assembly is latched to its home position. After installin the correction tape you can manually operate the lift arms to check the feeding of the tape. If you have a loca dealer you can probaly take your machine to them and they may install the tape for you at no charge.
Nov 15, 2009 | Smith Corona Office Equipment & Supplies
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Replaced Typewriter Ribbon & Now Correction Tape doesn't work
Is the ribbon that you installed a correctable one? It should have a yellow or orange knob to turn it. If that knob is blue, you installed a multistrike or non-correctable ribbon.
The only other thing is you have the correction tape in backwards
Jan 12, 2009 | Brother SX-4000 Typewriter
Installing correction tape
This tape comrs in two small cassettes the full one loads on the L. side of the printer the tape goes across lower than the ribbon and wraps on the R. cassette.
DickyO
Aug 28, 2008 | Office Equipment & Supplies
Brother ML-100 Typewriter Logo
832 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
