Question about Epson Stylus C66 Inkjet Printer
Cannot get print head to move to renew ink - Epson Stylus C66 Inkjet Printer
    Problem Solver:
  • 5 Answers
Unplug printer electric cord. lift print head cover & manually slide over the heads attached to the bar.it won't break.
Posted on Sep 23, 2009
5 Suggested Answers
SOURCE: Brother DCP-120C Printer - Does
have you recently had a paper jam. somtimes pieces of paper can become trapped under the print head which restricts the printing. if there is and its been there for a while the print head may need to be wiped/cleaned( a bit tricky) then a couple more print head cleans.
Posted on Nov 05, 2008
  • 3600 Answers
SOURCE: Ink clog between magenta cartridge and print head.
print head may be burned out try cleaning it then tap the cartridge and try a test page to see if it prints, if it still does not work try a new cartridge if that does not work then the print head is burned out, it may be under warranty you can go to www.hp.com and input your model and follow the trouble shooting guide and if you can't fix it you can register for free live chat help with the problem and it may be under warranty, many printers are having problems with this color cartridge drying up and causing problems not only hp but other brands as well. I suspect the pigment drys up but am not sure about it.
Posted on Feb 11, 2010
MUKHTAR
  • 2017 Answers
SOURCE: Print head moves but doesn't print.
make sure the knb level is set to 0 there is adjustment of head and roller distance .just adjust the lever .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 17, 2010
Patzky
  • 240 Answers
SOURCE: will not print . print head moves but no print.
Since this is an inkjet machine, there should be a way to force the printer to go through a self cleaning which should clear the print head of any blockage.
Posted on Mar 25, 2010
Kodak printers 7 and 9250 esp not printing.
If you do not print weekly with a Kodak printer, the ink can dry inside the heads and they stop printing. I have had this happen to two of my Kodaks. To prevent this, if you are not using them regularly, print a test sheet weekly and you should have no problem. At this point, your best bet is to order new heads for your printers and then maintain them with weekly test prints.
Mar 31, 2014 | Kodak Office Equipment & Supplies
Dont know how to replace printercartridges in mx700
Install the print head or ink tanks properly following the procedure If reseating or reinstalling to clear an error, the ink tanks and print head must first be removed.1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.Note: When the top cover is opened more than ten minutes, the print head moves to the right side.If this occurs, close the top cover, and open it again.2. Open the paper output tray.Note: When installing the print head, roceed to step 3.When installing the ink tanks, proceed to step 6.3. Raise the print head lock lever.4. Pull out the print head from its package, then remove the orange protective cap from it.Note: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>.Doing so may cause printing problems 5. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.6. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.7. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.Note: - Do not touch the ink tank contact <1>. Doing so may occur printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
8. Insert ink tanks into the print head.1) Insert the ink tank into the Print Head.(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.(3) Ensure that the ink tank lamp lights red.Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes. On: The printer is ready to print. Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank. Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.- Off: An error has occurred and the printer is not ready to print.10. Close the top cover.Note: When starting printing next time, the print head cleaning launches automatically.During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
Sep 20, 2011 | Office Equipment & Supplies
How to remove ink carriage
Ensure that the printer is plugged in and then turn it on by pressing the power button on the control panel.
Lift the top cover on the printer to expose the print heads.
Press the ink button (has an image that looks like an ink droplet beside it) on the control panel and then release it. The print head carrier will move to an accessible position inside the printer, with the first empty print head stopping under the ink out mark (the ink droplet with the line through it) located just above the carrier.
Press the ink button again and the print head carrier will move to the next empty print head. Continue pressing the ink button until the printer has acknowledged all the empty print heads and then the carrier will move to the print head replacement position.
5
Flip the print head carrier cover forward.
6
Choose an empty print head and grab it with your thumb on the front of it and your index finger on the back. Press in on the tab on the back of the print head and lift it out of the carrier.
7
Wrap the print head in a paper towel so that ink does not leak on anything and dispose of it.
Jun 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My canon pixma ip1300 is showing service error 5100, not printing and yellow light blinks five times thanks in advance..........
Solution: Install the print head and ink tanks correctly iP3000 / i560
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Power on the printer.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
    Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
  5. Remove the print head from its package and remove the orange protective cap.
    <1> Electrical Contacts and Print Head Face's Nozzle Area
    <2> Ink Supply Filters
    Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
  6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
    Next, install the ink tanks.
  7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
    Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
    <1> Removed correctly
    <2> Removed incorrectly
  8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
    Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
  9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
  10. Close the inner cover and top cover.
    Note: Check that each ink tank is installed in the correct position:
    Properly installed:
    Improperly installed:
    <Left Image> The M ink tank is not fully seated.
    <Right Image> All ink tanks are not fully seated.
Dec 03, 2010 | Canon PIXMA iP1300 Printer
How do you remove used ink cartridge?the printer is out of black ink
Removing the Print Head / Ink Tanks Instructions to properly remove the print head or ink tanks. Remove the ink tanks before proceeding to remove the print head.
Remove the Ink Tanks
  1. Confirm that the printer is powered on.
  2. Pull open the paper output tray.
  3. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  4. Open the inner cover.
  5. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
Click to return to the top.
  1. Raise the print head lock lever.
  2. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
Feb 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I have a Xerox 8560MFP printer with the following error code. 07010.43:39050 Any help would be appreciated
Your print head is stuck. Either the print head block has gotten ink in it and will not allow it to tilt, or the print head wiper is tacked, ( stuck) to the print head not allowing it to move properly.
Jan 11, 2010 | Xerox Phaser 8560MFP Laser Printer
C86 Goes through printing process but nothing prints.
Have you carried out 2 or 3 head cleaning cycles? If not, do it. Is there ink on paper now after this cleaning? If so, but it is streaky, leave the printer for 24 hours and repeat the head cleaning. If not, you must soak the heads for at least 24 hours - use print head cleaning fluid or distilled water NOT TAP WATER. Proceed as follows:
Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move by hand. Move it out of the way to the left. On the right you should see the print head parking area. There is a rubber cup that is designed to fit under the print head to keep the ink from drying out. Using a syringe or dropper, fill this cup with print head cleaning fluid. Then gently move the print head as far as it will go to the right. The print nozzles are now bathed in print head cleaner. Leave it for at least 24 hours, then repeat the cleaning cycle process.
Jan 28, 2009 | Epson Stylus C86 InkJet Printer
Brother DCP-120C Printer - Does not print black, Black and magenta cartridges renewed with new Brother cartridges. Black ink level reset OK but not magenta. Have tried automatic head cleaning but still no...
Nov 04, 2008 | Office Equipment & Supplies
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
4. Put back the inner cover and close the top cover.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Epson Stylus C66 Inkjet Printer Logo
153 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
