Question about Dishwashers
Each cycle starts off OK until the first discharge of water. after refilling the machine goes into the F2 mode. pressing start discharges the water and the crcle repeats itself. the discharge hose set-up is OK,the safety pan is dry and the water level inside machane appears to be as it should be.
  • 1 more comment
  • ron73 Jun 04, 2009
    I have an ASKO model 1876
    like I stated before the pan is DRY . All the water drains out . IT fills to the proper level. my problem is only on the second cycle of each wash selection. This appears to be electrical rather than mechanical.
    Use a torch ?are you English?.
    Please help thanks ron
  • ron73 Jun 06, 2009
    I wont know if this solution works until I purchase a new control board @ $350.00.
  • 6,784 Answers
Ok, this is a control issue. the timer/control seems to be malfunction. simply replacing the timer/control will fix this issue.
Posted on Jun 05, 2009
    President:
  • 987 Answers
Which model diswasher do u have...
Posted on Jun 04, 2009
Kenmore Elite dishwasher takes water and discharges it, but will not start washing.
You must have a control panel problem, nothing else I know of causes this.
Sep 21, 2016 | Kenmore Washing Machines
Why does spin cycle cut out before hitting max RPM?
G box or timer not staying on long enough
Sep 03, 2015 | Washing Machines
LG WM2101H won't dry until many cycles
Won't dry? I guess you mean spin enough water out? Depending on age, warranty, It sounds like a worn or bad drive belt or possibly a problem with the discharge pump not working properly.
May 04, 2015 | LG Washing Machines
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My B66 will not allow anything to come out of the dischare side, tank and water valve on supply side are all clear and De-scle mode is showing and started De-scle procedure but it will not discharge...
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 24, 2011 | Keurig B66 3-Cup Coffee Maker
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Will not discharge water or go into spin cylcle.
I would have to guess you have a dead spot in the timer. If it stops moving, it would still tick like a clock but the internals of it are not catching to send it into discharge and spin.
Apr 03, 2009 | Washing Machines
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
