Question about Dell Dimension 4400 PC Desktop
Windows will not shut down - when I click on "turn off your computer" I get error message that says "Windows had experienced a problem" but it will not shut down
  • charlenessi Jun 04, 2009
    It just started this am. I tried to shut down by going to start but all I get is a notice that "windows has experienced a problem" and asks me to send an error report. I finally unplugged the computer and when I got it back up, I got a blue screen. Unfortunatly, I did not think to write the stop code down.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Does this happen every time you use the PC or has it happened just now?
  • 48 Answers
If you have the disks that came with your computer, you may want to go ahead and use them to restore your system.
Posted on Jun 04, 2009
When the computer turns on it says.... " Application explorer.exe encountered a serious error and must shut down. Just purchased the computer and it will no go pass this error message
"Application explorer.exe encountered a serious error and must shut down"means sometime in the past, someone must have installed the OS incorrectly or has deleted something vital, which is why this error is occurring. The only way to bypass this is to reinstall windows OS using the CD that was provided for you, and this error will disappear.
Jun 29, 2011 | Sylvania G-Netbook
Laptop shut down error
The DDR2 RAM memory has failed and must be replaced.
You can get a new one from here
http://www.edgetechcorp.com/memory/upgrade.asp?cid=28784
Jul 09, 2010 | Dell Latitude D410 Notebook
I have a toshiba L505D it has windows seven on it and the message when turned on says windows error recovery and also says windows failed to start a recent hardware or software change might be the cause.
i guess you dont turn off the computer safely, how do you turn it off? do you just press the power button?
if u do so then dont! click on start, then click on the shut down button on the right hand bottom corner. like this
Apr 27, 2010 | Computers & Internet
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue
Mar 05, 2010 | Microsoft Windows XP Professional With...
My computer starts to load windows, then loses all power,
Does the same thing happen when you try to load the BIOS. (press keep pressing F2 when you turn on the computer). If it happens while the computer is in the BIOS window then its your power supply that is fried.
It does sound like the power supply is fried though. In which case the laptop will need to be taken in for service.
Oct 03, 2009 | Toshiba Satellite P100 Notebook
Windows xp screen freeze
try reinstalling vmware and XP if that does not work you should get parallels
Mar 16, 2009 | Microsoft Virtual PC 7 with Windows XP...
Button monitor problem
Disable all startup items. Click on Start> Run> Type msconfig then press enter. Click on the Start Up Tab the click on Disable All. Click close and restart your computer.
Your system should be starting up faster compared before.
Feb 08, 2009 | Dell Microsoft Windows XP Home Edition
Windows Explorer error after pressing Start -> Turn Off Computer!
Do you close down your applications first before shutting down? If not, give that a shot. If that fails try closing things down in the System Tray (icons by the clock). Try these things first and if that doesn't work, I have a few more things to try.
Jan 16, 2009 | Microsoft Windows XP Professional for PC
Kernel stack inpage error
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Feb 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Dimension 4400 PC Desktop Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
