Question about Whirlpool GD5SHAX Side by Side Refrigerator
Philips AMB595/PH Fridge Hinges
Any ideas where I might obtain top and bottom hinges for this rather old fridge, or failing that have you any idea where I might obtain be able to obtain a replacement spring for the hinge. ( The hinges are "hettich")
  • 1462 Answers
SOURCE: freezer door needs to be raised
just put some washers (plastic washers are best) on the hinge pin to raise the door
Posted on Nov 16, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
  • 163 Answers
SOURCE: change sides for hinges
doors are reversible but a little work.once you start taking hinges off you will see inserts that are covered with a plastic grommet.pull those out and put grommets back on other side.you should see it is very easy but time consuming.
Posted on Mar 06, 2009
  • 2418 Answers
SOURCE: my ed25pqxfwo2 fridge door seems slightly lower
You got a worn bushing you could try and make one out of PVC. May just be a loose hinge.
Posted on Jul 30, 2009
  • 457 Answers
SOURCE: my whirlpool fridge side makes a click sound when
sounds like the plastic holder on the hinge is are worn. the call them grommets also.
Posted on Feb 24, 2010
My samsung freezer door does not close all the way causing frost buildup. I have replaced the gasket and leveled the fridge.
The hinges usually have some adjustment on them. Two person job, or put something under the bottom of the door to support it. Loosen the hinges a bit, pull the door forward at the hinge which should close the gap on the other side. Tighten down the hinges and check again.
Jun 16, 2016 | Samsung Refrigerators
How to change door opening to other side
Hi Eleanor,
Without a specific model number I can only give general information, but, Kenmore fridges are all about the same, so here we go. Take a close look at your unit. You should observe several small plugs inserted on the side of the doors that don't have the hinges currently mounted. These inserts cover threaded holes that are used to mount the hardware for the hinges. If your fridge has two doors one above the other. remove the top hinge hardware, lift the door up off of the bottom hinge pin. then remove the bottom hardware on the top door. Typically the mounting screws are either phillips head or 1/4" hex head machine screws. You should now see that there is now a threaded hole in the same position on that side as the plug in caps on the other side. remove the caps from the one side and insert them in their respective holes on the other side. the door hinges will attach to the now exposed holes on the side that the plugs were removed from. But not yet. First remove the top hinge hardware on the bottom door, lift the bottom door off of the bottom hinge, and then remove the bottom door hardware relocating the bottom hardware to the other side. Install the bottom door onto the hinge pin of the bottom door hinge. Close the door then install the top hinge on the bottom door. Next install the bottom hinge and hardware for the top door, set the top door on the installed hinge, close the door add install the top door top hinge and hardware next. Same with the door handles. All of this info applies to the doors and the fridge itself.
Jun 26, 2015 | Kenmore Refrigerators
How do i fit the door on the other side
If you look at the opposite side of your refrigerator, you'll find one or more plastic covers which can be removed to expose mounting holes. You have to remove the doors from the current mounting position, remove the hinges and transfer them to the other side, install the doors and you're done
Jan 25, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
Doors
Yes you can change the way that the doors open. You will see on the very top that there is a hinge screwed into the top of the fridge and also below the freezer door you will see two hinges, then on the bottom of the fridge is the last hinge. You will see all the new holes on the fridge as to where to locate and place the doors properly. This is a easy job to complete just make sure that you do this one door at a time to make sure not to confuse the hinges. Please rate
May 29, 2010 | Kenmore 64802 Top Freezer Refrigerator
Dometic RM6270 Caravan Fridge.Hinges
you should be able to find any part you need
at
pplmotorhomes.com
they have always been able to help me in the past
Oct 14, 2009 | Refrigerators
Reversed a door
you should be able to reverse your doors just take bolts out on hinges pop out plugs on oppasite side
Aug 28, 2009 | Frigidaire FRT21H8 Top Freezer...
Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
Jun 06, 2008 | Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Whirlpool GD5SHAX Side by Side Refrigerator Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
