Question about Mitsubishi M-VR1000 Receiver
I have a problem with mitsubishi M-AV1 stereo receiver, if i connect my cd player on loop in, i have audio only on A speakers and only the cd player audio, not from fm tunner or tape or vcr or any other and the surround speakers dont have audio, but if i connect my player on tape in,vcr in or any other i have audio only on surround speakers full vcr,tunning,phono but speakers A dont have audio please help me, note: i recently change the pre integrated STK3122III....
4 Suggested Answers
SOURCE: Receiver not putting out audio
Probablemente tu aparato tenga dañados los amplificadores de audio.Llevalo a un taller para su reparacion.
Posted on Apr 01, 2008
SOURCE: Receiver
I have the same problem.
Is there a solutions besides replacing it?
Posted on Apr 11, 2008
Wolfman304
  • 720 Answers
SOURCE: My rear speakers are not
If you are adamant your M-VR800's menu has been setup correctly (i.e. 5.1 setup test tone confirms all outputs are working), then another possibility will be your disc audio setup.
When you inserted your movie disc, did you check your audio options on the 'disc menu' and select 5.1 from the disc menu?
Some disc menus offer an audio choice between Dolby 2.0 (stereo only), Dolby 5.1 or even DTS 5.1. In this case, you may need to manually choose your preferred audio option from the disc.
Posted on Sep 04, 2011
Need to know if a looped ground would make it where the tuner on my car stereo works fine but the cd player only uses the subs and no other speakers work ? On a 1995 BMW 325i
It sounds to me like you are using more than one amplifier and are using the blue wire (power antenna remote turn on) to turn the amp for the rest of your speakers. The blue wire turns off when leaving tuner mode, thus turning off the amp(s).
Dec 31, 2012 | Sony MEXBT2800 AMFMCD Car Stereo Receiver...
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
How to connect speakers to RCA model #RP-8070D
This unit is just a 5 disc CD player and cannot drive large speakers all by itself. Normally it is hooked up to a stereo receiver / amplifier which is what provides the power to drive the speakers which are wired to the back of the stereo amplifier.
If you have a home stereo, then just run the cables from the 2 AUDIO OUT connectors on the back of your CD player to the CD IN connectors on the back of your stereo.
Then turn your stereo on and select CD on your stereo input mode selector and you should be able to play the cds on your RCA and hear them through the stereo speakers.
If you do not have a stereo amplifier with speakers to connect it to, then you can always listen to it through headphones connected to the headphone jack.
Or if you have a set of self powered amplified speakers, like the kind you hook up to a computer, then you can run the AUDIO OUT cable from your cd player into those as well.
Good luck.
Apr 14, 2011 | RCA Audio Players & Recorders
How do I link my technics ge 70 graphic equaliser to my technics cd player sl-pd7a and my technics md player sj-md100 with phono rca leads . Thank you Simon
It would help to know what other electronics (receiver, maybe?) is involved.
If neither of those devices is a recorder, why do you need to connect them to the EQ when your receiver/preamp may have the facilities to connect the two playback devices directly; and the EQ in a Tape Loop?
Scenario A)
Assuming you REALLY want to have the CD and MD input through the EQ because you can't attach them any other way...
CD audio OUT to Line In; MD audio OUT to Playback;
EQ LINE OUT to whatever analog electronic inout you have in mind.
To hear and Equalize the CD set the Input Selector to Source, EQ REC button OFF; to hear the MD equalized set the Input Selector to Tape, EQ REC button OFF.
Scenario B:
You have a receiver with only ONE Line Level Aux input and a Tape Loop.
Insert the EQ in the Tape Loop. Attach one of the disc players to AUX and the other to the TAPE conenctions on the EQ.
Scenario C
You have a Home Theater System or Audio Vido Reciever.
The following is some boilerplate I made up that should explain some usage limitations.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Feb 01, 2011 | Technics Audio Players & Recorders
I have setup the DSP3300 hometheater. However when I play a CD, the audio comes from the front two speakers only. However there is no audio from the center speaker, rear speakers and sub woofer. Please let...
Unless the CD has DSP encoded sound, you will only get the usual CD stereo (2 speaker) sound, unless your receiver is able to apply DSP FX to a stereo source.
Oct 06, 2010 | Audio Players & Recorders
My Pioneer car stereo stops all audio signal after a couple of minutes regardless whether i'm playing a CD or the radio, but the stereo stays on. and the CD seconds and minutes still count, do you know why...
Check your connections to your speakers and amp and look for loose wires touching metal. I believe your stereo is fine, this has something to do with your speakers and the speaker wire
Jun 07, 2010 | Pioneer DEH-P6400 CD Player
I have a sony model STR D990. I use it for the TV sound system using video1 audio in. I want to use a wireless speaker, but when connected to the video1 audio out, I get no sound. I am looking for ideas...
Instead of trying to use the wireless speaker as a dedicated TV-audio-via-the-receiver speaker why don't you just attach it as recomended to the receiver for ALL of its audio outputs; or directly to the TV if that is the sole use you have in mind?
And since TV is an audio INPUT only to the receiver, simplify the audio hookup by attaching its analog audio to any available analog input BUT NOT one that funtions as a tape loop.
One more significant improvement I would recommend is to draw the TV-related audio from whatever device originates it but NOT the TV. THe sources are probably all capable of digital multi-channel sound while your routing of TV-analag-stereo audio limits the quality by washing it through the TV's questonable audio electronics while forbidding actual multichannel listening.
Jun 06, 2010 | Audio Players & Recorders
My car radio just stopped working? cd player works still
if your cd player still works and plays through the speakers, but your radio wont play through the speakers. i would suggest checking the antenna in the back of the stereo. most stereo's wont even play static if the antenna is disconnected. if the antenna is connected behind the stereo go to the passenger side door usually under the glove box is another antenna connection check to see if that one is intact. if that one is it usually means the antenna itself is not tight enough on the body.
Jan 07, 2010 | Dual XDMR-7700 CD Player
I need to hook up cd player
something i found today on google. hope it helps.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony CDX-CA400 CD Player
274 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
Todd Arndt
Todd Arndt
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
