Question about Water Heaters
Ihave a new water heater.Worked for 3 days.Now back to Ice baths
Th piezo electric pilot clicks and sparks, but won't light. the burner won't light,we checked for gas leaks, and there are none. What could have been installed improperly?
  • 62 Answers
All new tank-type gas water heaters for the home are designed with Flammable Vapor Ignition Resistant systems. It sounds like the unit has shut down because of a venting problem. If it is a Rheem or Ruud (General Electric for Home Depot) you have to reploace the heater. Other brands alow for resetting this safety device. Don't take chances with gas if you are not absolutely sure of what you are doing - have a professional licensed plumber check out the problem.
Posted on Jun 04, 2009
I can light the pilot and the burner will come on, but it won't stay lit. I bought a new pilot assembly and installed it. the burner and the pilot light still won't stay lit. This is the unit that...
Most gas water heater problems can be solved by having service technician perform yearly maintenance. Or by doing maintenance yourself.
This maintenance includes cleaning burner parts and combustion chamber, checking gas pressure and supply, bleeding air out of gas line, checking vent draft, making sure air supply is adequate and not exposed to chemicals, cleaning air intake. Also adjusting flame sensor so it is positioned correctly. If water heater is connected to electric circuit, the outlet must have correct polarity.
You can get gas to appliance indicates the gas control valve and water heater are not locked out. But the gas control valve thermostat can still be bad.
Open following link for illustrations, typical service manuals, and maintenance information, and images of gas control valve thermostats.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 20, 2011 | Reliance & Pilot Assembly for Natural Gas...
The piezo igniter clicks but the pilot will not light
are you getting spark out of it? when you click it can you see a small electric spark? if you see it spark, then the thermocouple will probably need replacing
Jun 15, 2010 | Fasco Bradford White Hot Water Heater...
Gas water heater: burner doesn't fire, replaced gas control valve
Hello,Don't worry about the rust flakes as every burner collects then and is normal.The new control should click.Please check incoming gas pressure supply 3.5"WC natural gas / 9"WC for LP.Check it at the piolt tube with a pressure dial meter,I assume the water temp now is cold.Did you change the thermocouple also as this provides the power to run the control?
Apr 22, 2010 | General Electric GE SmartWater Household...
Rheem Fury 42V50-40F. Piezo ignitor will not light the pilot light. A thousand clicks, still won't light. Mfg in 2005. Gas valve is on. Knob set to pilot, red button pushed --- I know how to light a...
Sometimes it is necessary to turn the temperature dial all the way back to the coldest setting with the gas valve in the off position in order to reset the safety on some gas water heaters. Give it a try
Jul 11, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Jun 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Trying to find out if my new hot water heater is shot
The red button you pushed on the hot water heater was probably what is called a "piezo-electric" ignitor. It's normal for it to make a snapping sound and then pop back out. It sounds like you just lost the pilot light.
That being the case, do this:
Turn the gas valve on the hot water tank to the "off" position - it should be silver in color and down low on the tank. You may have to push it down to do this
Leave it off for about two minutes or so
Rotate the valve back on to the "Pilot" position
Hold down the pilot gas valve - it should be red and immediately to the left of the main gas valve.
While holding the pilot gas valve down, push the other red button to the right of the main gas valve - this is the piezo ignitor - push it several times in a row quickly
The gas pilot light should light
You can stop pushing the ignitor now, but continue to hold down the gas pilot valve (the one just left of the main gas valve). Let this valve up after about another 20 seconds or so.
Now rotate the main gas valve to the "on" position
Listen carefully - you should hear the main gas light and feel heat at the water heater flue outlet on top - don't touch it with your hand - you could get burned
If no luck, repeat the process until the heater re-lights
TIP - the instructions for re-lighting the pilot should be written on the heater
Just a potential diagnosis - the thunder clap, if as close as you describe, may have been intense enough to create what is known as a "draft inversion" that may have snuffed out your pilot light. The air pulse came down the flue pipe.
Apr 08, 2009 | American Standard Water Heaters
Bosch tankless hot water heater 1600H
it sounds more like the ignitor thats messing up, if you are able to remove it and get a new one that would probobly do it for you
Nov 07, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
Sep 19, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Water Heaters Logo
196 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
