Question about Maytag MDBH955AWS Stainless Steel 24 in. Built-in Dishwasher
Dishwasher does not drain...stops in cycle...no matter what cycle
For example:  I pressed the light wash cycle, which should take around 80 minutes...dishwasher stops after about 8 minutes, and doesn't drain...has happened a couple of times, have had to drain by hand.
Also, the regular dishwashing cyle washes for a couple of hours, and stops...then starts again even when not pressed.
  • 6,784 Answers
HI, this is a control fault. the logic chips are malfunctioning. these chips are responsible for initiating the proper washing cycle sequences. you will need to replace this damaged control board asap.
Click here to order your new control board online.
Posted on Jun 04, 2009
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Clean light is flashing
As an example on a kitchenaid dishwasher when the clean light flashes 7 times this is a control error that be corrected you would press Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry with the door open and then close the door and press cancel. If your unit were a whirlpool dishwasher you can press hi temp heated dry hi temp heated dry with the door open which does end up lighting all the led's and when you shut the door makes the unit cycle into the wash stage. after you hear the unit letting water into it listen for the wash cycle to start and then press cancel. After the unit drains then you can set your unit to wash again. I will await your reply as to what type of unit you have before continueing on with a exact solution for your unit. Thanks
Rick
Oct 08, 2011 | Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
The washer still has water in it , It has stopped , there is a red light next to the tap svmbol on the controls ( don't think I've seen that lit before )
Are you please able to provide the model number of the dishwasher.
Also please confirm which cycle was it on and how far into the cycle did it stop. For example was it still swishing the water around in wash cycle or draining water out.
Oct 28, 2010 | Neff Dishwashers
Ge triton xl dishwasher
One answer is NEVER buy another GE product!!! I bought all GE Profile appliances when I redecorated my kitchen. Have had issues with every single piece. Refrigerator has been replaced twice (on 3rd one). Triton XL dishwasher will not reset...good luck getting it back to normal wash if you change a cycle...for example to run just a rinse. It is almost impossible to get it to reset. And don't get me started on the over the stove microwave. Never have been able to use the lights. Every time from day one I turn them on, the bulbs blow and the cover shatters. Absolutely no support from GE!!!
Dec 24, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Maytag MDBH955AWS Stainless Steel 24 in. Built-in Dishwasher Logo
405 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
