Question about Jandy AQUALINK RS TELELINK KIT
Aqualink Chlorine Generator not producing any chlorine
I recently (1month ago) replaced the generator cell (T-CELL-15) and now I don't see any chlorine being generated in my pool. I've use home kits as well as taken it to a pool store for testing with same results.
The display on the Aqualink says, it is generating chlorine and everything is fine. All my pool chemistry is fine too.
It has been set at 85% generation, salt level is at 3400 and I've run the chlorinator for 24 hours at a stretch now.. but yet, not chlorine.
I've called Hayvard and they say it is generating chlorine since the display says it is.
Any suggestions, pointers?
It shounds like that you might have a mustard algae issue. It feeds on chlorine. It is possible that your unit is producing chlorine but the algae is consuming it as fast as it can be made. You will need to do a shock treatment and use an Algae 30. It could be something else, but this is likely. You can google mustard algate treatments and read up on it to see if you have other symptoms.
Posted on Aug 04, 2009
What is wrong with my Aqua Rite Electronic chlorine Generator.
when unit goes off see if voltage from transformer if not bad transformer if os bad cell and sensor
Sep 09, 2016 | Hayward-Goldline Aqua-Rite Electronic...
Turbulent flo control
check chlorine of pool and then test at 1st return chlorine should be higher your chlorine m ight be locked and eating up the chlorine your generator is producing also check for phosphates in water or other contaminates
Feb 19, 2014 | Pool & Spa
Need new cell?
if u cell still work my suggestion is don't get a new one . the question is how do i know when you need a new cell ? you can check the control panel where the cell is connected will show a error code,also by cell when the pool is running and the cell generator is working ? take the cell apart and check for chlorine with a test strips if you don't read chlorine you got the answer ,
Jun 08, 2013 | Zodiac Duo Clear System Chlorine...
24' X 52" intex pool, I am having trouble with my cholinator not producing chlorine in the water. there are no signals or lights flashing. but when I test for the free chlorine on the strips is do
If you can remove your generator try and bench test it. Fill with pool water and do a chlorine test. Run the generator for a few minutes, unit should produce bubbles when the cells are turned on. Run another chlorine test and make sure it is higher than original test. You should also test your combined chlorines to make sure you don't have excess chloramines in the water. Also check for any buildup on the generator plates which should be acid washed, and verify salt concentration.
Apr 01, 2013 | Intex Automatic Salt Water System for ...
Jandy AQUALINK RS TELELINK KIT  Logo
715 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
