Apevia White US Laptop Keyboard for Acer Aspire 4520 4710
Problem for Apevia White US Laptop Keyboard for Acer Aspire 4520 4710
I need to replace keyboard from acer 4330. any
By nbaronny on Jun 04, 2009
I need to replace keyboard from acer 4330. any tips ???? Thanks
Best Solution
posted on Jun 04, 2009
Very Helpful)
leecom72
Rank: Guru
Rating: 89%, 2465 votes
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Apevia White US Laptop
Questions and Unsolved Problems for Apevia White US Laptop
Do you recommend Apevia White US Laptop Keyboard for Acer Aspire 4520 4710 ?
Answer
Answer
The wheel doesn't work for scrolling down. It's a new mouse and its wired.
Answer
Nothing happens when I hit the ''enter'' key on my keyboard - can you help? I use a laptop with an... (More)
Answer
acer laptop aspire 4710z witch driver use for crystal eye web camera
Answer
My acer aspire 4710 hangs when I play games! Everything passes the requirements but it always hangs... (More)
Answer
i cant create a restore point on my laptop. it says it has been disabled by group policy. i cannot... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apevia White US Laptop...:
Top Keyboard and Mice Experts
Rank: Guru Guru
Solutions: 14871
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Keyboard and Mice Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
