Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
WERE ARE THE INK CARTREGES LOCATED - Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
  • Brother Master
  • 4,338 Answers
Look on page 93 of the user guide for replacing the ink cartridges:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 04, 2009
How do I reset the ink so it recognizes a refill cartridge that is not the original epson ink cartridge. It was working just fine for days, and now it will not let me do anything. Is there a bypass...
The information I recieved.
Tuen the printer off. Open printer cartrege well.
Push row of cartreges manyally to the center of the printer bar. Remove cartrege in question.
Remove the outter lable on the cartrege. (It will peel off) be careful not to peel the plastic window off the cartredge or it will be useless.
Replace the cartrege back into the well to reinstall.
I did this SEVERAL times (everything up to removing the label but reinstalling) before FINALLY, I recieved a message indicating the cartrege was not a genuine Epson cartrege...do I wish to continue?
It appears in the window on the printer.
Mar 02, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
I was using this printer (Cannon Mp 540) since last one year in between I changed all ink bottes also now the ink cartreges are almost full, two days back I started this printer and I got message on screen...
Resume the printer
You need to use the Resume option to solve the error easily and simply. The printer must be turn off while selecting the Resume option. After holding down the Power button, you need to press down the Resume option. You need to continue this process four or five times. During this process, the counter absorber option will be modified and the issue can be solved. After completing these processes, you need to restart the printer. The error will be resolved after this.
Fix cartridge issues
The storage medium in a printer is the cartridge. If this has any issues, then also the printing process will not happen and thus the printer error B200 would occur. You could change this storage device to resolve this issue.
Proper driver installation
If none of the above solutions could resolve the issue, then the issue might be related to the driver of the printer. Failure of driver updation, incompatibility of drivers due to Operating System up-gradation, malwares are some of the reasons behind the failure of printer drivers. If you update the driver properly, then you could resolve most of the errors that may arise due to the driver issue.
Feb 15, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Won't print color at all. No error warning. ink cartreges are new. went through maint. procedure including deep cleaning.
try doing a nozzle check print out.. see if all the ink are able to print out from there.. else do a head cleaning few times to see if there is any improvement, if after few clean and still no ink out.. most probably the print head is out..
May 23, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Although my printer is connected, has been set up and sounds like it works when it's "printing" B&W printing doesn't work and colour printing is not coming out right. What's wrong?! The ink cartreges...
Sounds like the print heads are blocked. You should be able to perform a head clean in the printer properties within Windows. Do this a few times and the ink should gradually start to come through. If this doesn't work, it may need a service.
Dec 13, 2009 | HP Photosmart C4480 All-In-One InkJet...
My computer says there are no ink cartreges and i just put 2 new ones in
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Nov 20, 2009 | Dell 922 All-In-One InkJet Printer
Think its out of ink where do i put more in?
the fount of the printer should have a lift up panal you need to have it pluged in and on when you open it the cartreges should slide to the middle or side where you can replace them
Mar 27, 2009 | HP DeskJet F380 All-In-One Printer
New hp printer
Make sure you pull the tab off the ink cartreges before you put them in. Also make sure there are no packing tape/ tabs where you put the cartreges in.
Jul 27, 2008 | HP Photosmart C3180 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
