Question about Frigidaire Affinity ATF7000E Front Load Washer
My washer door isnt staying locked
When we shut the door it starts up for a minute then it beeps the door isnt locked.
  • 35 Answers
Your probably need to replace the door striker (two pronged plastic prongs) thats attached to the door with two screws, or, the door switch. The door switch can be accessed by taking off the top lid and removing the two screws in front of the machine. The switch is a whole lot more expensive than the striker. Be sure to pay attention on how the switch is wired!
Posted on Jun 05, 2009
I have a kenmore he2t washer that will not start. Door locks, buzzes for a minute then shuts off. No error codes. What could the problem be?
the door interlock is basicaly a heated switch
it locks then hold it locked
but there is a sensor to check its closed in the first place
i think the interlock sensor isnt right
replace the door interlock is the first step
http://www.ebay.co.uk/itm/WHIRLPOOL-SPORT-MAYTAG-EPICZ-KENMORE-HE2-Door-Lock-W10253483-46197023640-8540772-/141476775106?pt=LH_DefaultDomain_0&hash=item20f0ac44c2
here is one i found on ebay
its not cheep so shop around a bit now you know a few equivelant types .,.. and models
Dec 07, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays...
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Nov 27, 2012 | Whirlpool WTW5600X Washer
My whirlpool duet washer stops towards the end of the cycle and flashes 6 then F. The door stays locked and the washer beeps. It has happened before, the machine is about 6 years old, how can I fix
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Feb 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I just replaced the door latch on my kenmore front loader washer model 11047532601 the door locked light doesnt come on and the door locked light isnt coming on all i get is beep beep beep
You have a bad CCU. This is the control board on the top of the unit. Remove the top, three screws on the back. The board clips into the position. You can try to unplug the wires one at a time, the control will probably have to be replaced.
With the model I would be able to better assist you.
Mar 31, 2011 | Kenmore HE2 Plus Front Load Washer
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
Start and after few minutes show "dl" f
easy fix, door lock failure, replace door lock asm. on old duet this part is same as GE, and samsung parts. new duets differ
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer won't start door locked
Likely the ECU is failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Pushing Start Button only results in "Beep, beep, beep"
Need to check that the lid is shut properly and the door is locking. You don't mention an error code in the display. Make sure there isn't one showing.
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
201 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
