Question about Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A
Wanting to know if I can move a freezer right after unplugging it? Or does one have to leave it sit awhile first?
Refrigerators or freezers can be moved right away as long as they are empty and the doors are secured properly. Frozen objects left inside a unit can damage the interior and should be removed. Be Gentle... Never drop it or shock it in any way when unit is still frozen inside. Be careful if using a hand truck or dolly as care must be taken to avoid damaging the condenser coils either behind or underneath a unit. Lastly, wait 5 minutes before plugging the unit back in so that pressures may equalize in the system. Good Luck!
Posted on Jun 04, 2009
Red light on
you should have have let it sit till the compressor equalize if it was running,you may have ruined the ptc overload relay that protects the compressor,try unplugging it and leave it off for an hour,then retry it,if this doesn't help then replace the ptc overload on the compressor body,they just unplug off the compressor
May 09, 2010 | Whirlpool 7 cu. ft. Chest Freezer EH070FXM
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
Homemaker chest freezer is hilling but not freezing. HAve tried defrosting and compressor sounds fine?
Try thawing out the freezer....Put all your food in a cooler, unplug the freezer and leave the door open, let the freezer sit for a few hours then plug it back in, if this doesnt help you may need to recharge your refrigerant....If you have a model you can refill hope this helps
Oct 01, 2009 | Freezers
Blowing air but not cold
Well lets start by saying that is possibly the "cause", and we certainly know the "effect", now for a solution. With any luck all you did when tipping it was cause a wire to come loose, or the relay/overload on the compressor is not making a good solid connection.
*FIRST; unplug the unit from the wall or shut off the breaker...best to unplug, then you're sure.
*before working on the compressor or sealed system you should verify through your owners manual you will not void any future warranty as some units have a 5yr. sealed system including compressor warranty and others have a 10yr. compressor part only warranty as well.
since the fan is working (you indicated it was in the post by saying it was "blowing air but not cold).
look in back of the unit, at the bottom sits the compressor. on the right side of the compressor may be a plastic cover, it's small and kinda square. This cover houses the start/overload device. if it's held in place by a metal clip, remove it (careful, they can and usually do have sharp edges). once the cover is removed, examine the connection to the compressor, is it loose ? if it IS. awesome. secure it in place and try starting the unit now. if it is NOT loose, take it off and shake it in your hand. does it rattle (like something inside is in a million fragments)? if it does, it's toast, you can find a replacement at an on-line parts depot or a local appliance parts supplier. you may opt for a "all in one" start pack. you should be able to score one (#RCO410) for around $15-$20us. make sure you get the right size. there are some good for residential compressors up to 1/8 hp and others for compressors up to 1/3. you don't want one too powerful or you'll damage the motor windings, but you need one powerful enough the start the compressor under a slight head pressure load.
if the unit has been "seemingly" running, as soon as you unplug it, reach to the back and put your hand on the compressor, careful it potentially could be very hot. that being said, if it is hot, you know the compressor has actually been run, hence "trying" to pump/cool. If that is the case, it is likely the worst case scenario. this would mean you've got oil in the system where you don't want it and the "cap" line is plugged. you can try leaving it unplugged and upright for a long period of time to see if the oil all runs back into the compressor, but likely it will need the system opened and pumped out, and that can be very costly and time consuming.
that should give you a bit of a reference of what may be happening. beyond that I'd seriously consider an expert tech.
good luck
Sep 20, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
Jul 30, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Will it harm an upright freezer if you leave it unplugged during the summer when not in use. It is sitting in a mobile home that gets very hot
Sometimes it does hurt it and sometimes it doesnt. When a freezer sits for any length of time sometimes the freon will leak out. It would be best to leave the freezer plugged in.
Jun 30, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
After freezer was moved not getting cold
Unplug the unit and leave it undisturbed for 24 hours. Plug the unit back in again and see if it will come to temp.
Jun 02, 2009 | Freezers
Quit working after I moved it to clean behind it.
Hi, perhaps leave it plugged in for more then 20 minutes. It could be in the middle of a defrost cycle. The cycles on these ones happen whether it needs to or not. If it happened to be in a defrost cycle when you unplugged it, you will have to leave it plugged in until the cycle is over at which time it will fire up.
Just curious did you tilt the fridge on its side in-order to move?how did you move it?
Dec 19, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A Logo
120 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
