Kodak com go aiosupport
When I print a letter the printer will print two lines clearly then the next line is not clear. It looks like the line was printed with a space in the middle of each letter, looks like a white line running the length of the sentence. I have printed a test page and everything looked fine. Can you tell me what to do?
  • 163 Answers
SOURCE: Printing garbage
my dear sir plese reinstall the printer software after deleting first installation and also increse the memory of your printer ,printer memory is not matching with your CPU memory
Posted on Sep 21, 2007
SOURCE: poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Posted on Aug 19, 2008
don_farr
  • 1018 Answers
SOURCE: Word text document not printing clearly on every line.
What version of Word do you have? What OS are you using?
Can you append a print to file to this thread so that I can see what data the printer is being sent?
Posted on May 10, 2009
  • 4044 Answers
SOURCE: Every few lines of print there is a thin white
Go throught he maintenance menu and perform a Deep cleaning of the printer nozzles. This will use a lot of ink so use your current cartridge to do this. Once teh cleaning cycle is complete, replace teh cartridge and align the heads with the maintenance menu selction.
Posted on Sep 11, 2009
  • 164 Answers
SOURCE: blank streaks through the lines of the printed
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
Jan 03, 2015 | Kodak ESP Office Equipment & Supplies
How can i clean my printer ? difficult to read all the lines.. tops of some of the lettering is gone or cannot read? some of the lines r clear and then the next lines r faded or letting is not dark enough...
The print heads are all gunked up with extra dried ink. Go to start, to the control panel next, to the printer, right click on your mouse and the preferences for the printer should come up and MAYBE it will allow you to clean the print heads. Not all canon's have this ability.
Aug 22, 2010 | Canon Office Equipment & Supplies
Kodak esp 3 printer will print but has lines through letterring o
Suggest you contact Kodak directly as it may need a replacement part
Jul 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer will not print clearly
im sure you have heard this put are you sure you have the right driver, Or your printer cartridge could be dispersing too much ink at one time try replacing them.....
Driver Download
Apr 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Double Blurry Print
Usually hairs sticking to the underside of the print head causes this.
I gave a solution to an Epson CX6400 user who needed to physically clean his print head. Look this up in the solutions. It involves using folded kitchen roll under the print head with the printer switched off and the head unlocked and free floating.
It would take me ages to type this again so please look this up.
The user had jammed paper and cleared the jam but had paper stuch to the underside of his print head.
I hope this helps.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Jan 17, 2009 | HP PSC 1210 All-In-One InkJet Printer
Prints 2 or 3 pages then fades out
There is a problem with your printhead and it needs to be replaced, but this is a completely free process, kodak won't charge you anything for it. You need to call their support center to have it replaced, or you may go to their website on kodak.com/go/aiosupport to replace it yourself on line.
Nov 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EasyShare 5300 printer
my printer is saying printhead installed wrong and its not i took it out three times and still same thing no fix service error code
Aug 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
18 people viewed this question
k24674
Marvin
Marvin
