Question about Sram Force Crankset 53/39
SRAM FORCE crank lock
Running "SRAM FORCE" with "GXP GIGA PIPE" on cross frame. Crank does not adjust properly,and locks while peddling.
  • Anonymous Mar 29, 2014
    I have a 2013 giant xtc composite 3 it has a sram s 1000 crank set with gxp bb I want to change to shimano xtr what is the right bb to do so
    President:
  • 1,138 Answers
If it won't pedal you probably have a broken bottom bracket. This needs to be done in a bicycle repair shop as you need the right tools to disassemble it.You will also need the exact replacement parts as they come packaged with the kit and diagrams for installation. Sorry I'm not more help.
Posted on Jun 05, 2009
Tip
GXP Integrated Bottom Bracket Adapter
Follow this link and see how to use <span>GXP Integrated Bottom Bracket Adapter</b></span> <span><a href="http://www.sram.com/_media/techdocs/GXP%20Integrated%20Bottom%20Bracket%20Adapter%20Rev%20C.pdf">http://www.sram.com/_media/techdocs/GXP%20Integrated%20Bottom%20Bracket%20Adapter%20Rev%20C.pdf</a></b></span>
on Mar 01, 2011 | Cycling
How do you remove / service the bearing on the bottom bracket? I have tried to open the assembly but have been unable to separate the crank. There is a defininte creak when under load and "sometimes"
On a bike???! On a bike to service the bearings
at the crank (peddles) remove chain
rrmove peddles then there will be a lock
nut at base of peddle crank remove it
then slide the whole crank out of the
opposite side an there you go you will
have you bearings in plan view if bearings
are busted replace if they are good
clean an repack with grease an reassemble
Jun 13, 2014 | Merida Mission 3000-D
Today while riding with sram force group set in the small chain ring in front while shifting to the smaller cogs in the back cassette there was alot of chain slack to the point that the chain was not...
Riding small-small is called cross-chaining, and is not recommended. On a double chainwheel bike at least the smallest and sometimes the next smallest should not be used. On a triple it's more like the 3 smallest. Nevertheless, the derailleur pulleys should take up the slack at least, if you have not made any changes to chain or derailleur. The spring on the pulley cage may be broken or weak. You need to get in-person help at a bike co-op or bike shop.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Feb 16, 2018 | Sram Cycling
Slow and tight Sram red Crank
I'm sorry, but if you don't know how to order the correct BB or properly install it you should not be building a bike from scratch, as this is probably the first of many problems you will have. As for YouTube it's not a reliable source of technical info. Try this site: http://www.parktool.com/blog/repair-help
OR Contact the frame seller and find out what BB the frame takes or contact the seller of the BB and ask for assistance.
Jul 28, 2017 | Sram Red
Hi, my front mech wont change smooth. It is a compact chain set. From new it would never change like it should. takes lots of time and peddling to change.I
If not too late return it to the place that sold it to you and request it be fixed to work properly. Otherwise take to a bike shop or bike co-op. Alternatively go to Repair Help or Sheldon Brown Bicycle Technical Information to learn how to fix it yourself
Nov 10, 2017 | Sram Red
How ti adjust the clutch on a2008 harley davidson ultra classic electric glide
To adjust the clutch, follow the clutch cable down to the frame front downtubes and find the cable adjuster. It's usually covered with a rubber bellows. Slide the bellows up or down exposing the adjuster. Loosen the lock nut and turn the cable adjuster in all the way getting as much slack in the cable as possible.
Then take the derby cover off the primary. In the center of the clutch assembly, you'll see an adjuster screw and a lock nut. Loosen the lock nut. Turn the adjuster screw inward until you feel a resistance. DO NOT FORCE THE SCREW OR YOU'LL BREAK YOUR INNER CLUTCH HUB. If you need to, back the screw out and turn it back in just till you feel the resistance several times to get the feel of it. Once you feel the resistance, back the screw off 1/2 turn and lock the lock nut down.
Then, go back to the cable adjuster and turn the adjuster barrel out until you have about 1/8 inch of freeplay in the cable. Tighten the lock nut and replace the rubber bellows. Replace the derby cover.
Good Luck
Steve
May 25, 2011 | 2008 Harley Davidson FLHRC 105th...
Agusting the clutch
To adjust the clutch on your Fat Boy, follow the cable down to the frame downtubes. You'll find a rubber bellows type cover. Slide the cover up or down to expose the cable adjuster. Loosen the lock nut and turn the ajuster inwards making the cable as short as possible.
Now, remove the derby cover. In the center of the clutch assembly, you'll see a screw and a lock nut. Loosen the lock nut and turn the screw inward just until you feel a resistance. Do not force the screw as you'll be releasing he clutch. Go in just until you feel the resistance. Try is several times to get the feel of it. Once you feel the resistance, back off on the screw between 1/2 and 1 full turn. Hold the screw in that position and lock the locknut.
Now go back to the cable adjuster and turn the adjuster outwards making the cable longer until you have about 1/8 inch (3mm) free play between the lever and the lever stanchion. Lock the lock nut and reposition the bellows cover.
Good Luck
Steve
Aug 14, 2010 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Chain rubs inner front derailleur while in lowest gear.
on front derailleurs there should be two small cross head screws one has L(lower) next to it the other has H(higher), you will need a cross head srewdriver, you simply losten or tighten the 2 screws and it will adjust the position of the derailleur to your crankset and it that completely fails then you might need to try a different crankset
Feb 26, 2009 | Sram Cycling
How do we adjust an aluminium door?
the door has a cam that has to be adjusted to force the pin up
call a local glass company and ask them where the adjustment is located
there is usually some type of access plat near the bottom of the door frame close to the hingee on the inside close to the bottom
Nov 26, 2008 | Locks & Locksmithing
Sram Force Crankset 53/39 Logo
176 people viewed this question
Top Sram Cycling Experts
Michial Gueffroy
Mike
dante
Are you a Sram Cycling Expert? Answer questions, earn points and help others
