Question about fedora Linux Operating System
Installation to hard drive
Hey guys, i got fedora running off this image i burned to disc and everything boots up fine but when i select install to my hard drive and select to delete all other linux systems and then install, it gets about 1/10th of the way then the whole system freezes.
any ideas how to install fedora without this problem
  • Narayanan Srinivasan May 11, 2010
    Did you try with a different disk? It could be a problem with the disk.
  • 144 Answers
It may be a bad image
Posted on Jun 05, 2009
Windows 7 installation disc doesn't see SATA hard drive
If your motherboard's BIOS is properly configured for SATA controllers and you burned the Windows 7 RC1 ISO image correctly, Windows 7 should recognise and install on a SATA drive without any third-party drivers. Consult your motherboard's User's Guide for assistance in setting up the BIOS properly.
In case Still Having Problem Then Follow Us For Computer Support For On : Computer Support
Feb 06, 2014 | HP Pavilion dv6130us Notebook
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Can i reboot my ps3 using lenux boot disk
Yes, Ofcourse.
Instructions
    • 1 Select and download a Linux distribution to download. Your options are Ubuntu, Fedora, OpenSUSE and Yellow Dog. Ubuntu and Yellow Dog have better support for PS3 than OpenSUSE and Fedora. Links are provided in the first Resource.
    • 2 Locate the boot loader included with your Linux distribution of choice and rename it to "otheros.bld" so the PS3 recognizes it. Your bootloader is either named "kboot" or "petitboot" followed by a version number.
  • Create a folder named "PS3" on the CD or Flash drive. Create another folder named "otheros" inside the "PS3" folder. These folder titles are case-sensitive--enter them exactly as they appear here.
  • 4 Save the "bootloader.bld" file in the "otheros" folder. If you are using a CD, burn it now. See the second Resource on how to burn a CD using tools included in Windows.
  • 5 Insert the Flash drive or CD into the PS3.
  • 6 Go to the "Settings" column of the PS3 main menu, select "System Settings," then "Install Other OS." The PS3 then searches for and starts installing the boot loader from the Flash drive or CD.
  • 7 From the "Settings" column again, select "System Settings," then "Default System." Choose "Other OS" from the options listed on the right.
  • 8 Burn the .iso of your Linux distribution of choice to a CD, if you want to boot the PS3 from a CD. If you're using a Flash drive, see the third Resource on how to put a running Linux installation on a Flash drive.
  • 9 Remove any disc already in the PS3 and turn it off.
  • 10 Insert the CD or Flash drive. The Flash drive goes into one of the PS3's USB ports, located on the front face, in the bottom right-hand corner. If you insert a CD, the PS3 automatically turns on.
  • 11 Turn on the PS3, if it hasn't turned itself on already. Select your Linux distribution from the boot loader menu to boot the PS3 from the Flash drive or CD.
  • Jun 05, 2013 | Computers & Internet
    Ya if i only could reload win7 and yes u will lose all info on hdd even the dummy password he put on to lock hdd amazing only thing it wont reload windows
    Step 1:
    Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
    Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
    Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
    Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
    your computer will automatically restart it might restart 2 times one to finish the installation
    the next will be because the operating system is loaded and will boot from your cd
    Step 2:
    For Windows users who switch and upgrade from Windows Vista, one difference will be immediately noticeable when installing or upgrading to Windows 7, i.e. Install Windows 7 setup wizard no longer prompts or asks for user selection of which edition of the operating system to install. Instead, each Windows 7 DVD disc or Windows 7 ISO image will automatically install the preset specific edition which it's confined to.
    Although Microsoft does not provide an universal "one disc rules them all" Windows 7 installation media, however the function is indeed supported. User just need to delete and remove the ei.cfg from any Windows 7 ISO disc image to convert the image into universal disc of any edition Windows 7 installer. For user who has the ISO image of Windows 7, and wish to make it an universal installer for any and all supported editions of Windows 7, as shown in illustration below, now has an easier way to modify the ISO. Instead of manually unpacking and extracting the content of ISO image (or copying files from DVD) to HDD, deleting the ei.cfg and then repacking or rebuilding installation files back into ISO to burn, user can now eliminate troublesome procedures by making use of "ei.cfg Removal Utility". clip_image001.jpg The ei.cfg Removal Utility is a simple tool that will disable the ei.cfg from any Windows 7 ISO disc image, thereby converting the image into a "universal disc" that will prompt the user to select a preferred edition during setup. ei.cfg Removal Utility works directly to patch the ISO image, by toggling the deletion bit in the UDF file table to instruct the operating system to ignore and remove ei.cfg, or treat it as if it does not exist. Best of all, ei.cfg Removal Utility can reverse the patching to restore the ISO disc image to its original state when the tool is been used to apply on a disc image that previously been patched by the utility. ei.cfg Removal Utility is a standalone portable app, and thus no installation required. In fact, the program does not have much user interface. After selecting the target Windows 7 ISO, the disc image will be patched right away. So make sure a copy of ISO backup is done. Download ei.cfg Removal Utility: eicfg_removal_utility.zip
    Feb 14, 2013 | Computers & Internet
    Hp proliant dl380 g4 not booting from hard drive
    I bought an HP DL380 G4 from here, and called them up any time I had a question like this. These guys were amazingly smart. Perhaps you can call them up and pretend to be a customer?
    May 07, 2012 | HP Compaq ProLiant DL380 G4 Server
    Help installing linux
    1. Download an ISO image corresponding to your Computer's Processor Architecture (i.e. 32 bit or 64 bit)
    2. Using an Image Burner application like ImgBurn, burn the ISO image to a blank CD or DVD (depending on whether you chose to download a CD Image or a DVD Image)
    3. Restart your computer with the newly burned CD/DVD Image of Fedora
    4. Now select it during the Boot Up process as the medium to boot from (i.e. press "F9 key for Boot Menu")
    5. Fedora will boot automatically in 10 seconds. Launch the "Install to Hard Disk" application after Fedora boots; then follow its prompts.
    Done.
    For more information refer to this link for Official Documentation
    Sep 27, 2011 | fedora Linux Operating System
    How to install linux fedora 7, already i am using windows 7, now i want to use dual os's , please tell me how to install linux.
    WARNING: I will not be responsible for any data loss that occurs. It is recommended to backup your hard disk to external media before commencing any of these operations. 1. Download and burn the Fedora LiveCD. It is recommended that you use the latest version, Fedora 14, instead of 7, but you can use Version 7 anyways. 2. Boot up with the Fedora LiveCD. Select Install. 3. Follow the instructions displayed onscreen. When you reach the partitioning screen, you will need to resize your Windows partition. Resize it to a reasonable size (1024MB =1GB). Leave at least 5GB for Fedora to install. 4. After resizing, select the "Use Free Disk Space" option, and continue installing. 5. Your system will be installed with Fedora and the GRUB bootloader. The GRUB bootloader will allow you to boot into both Windows and Fedora.
    I hope this post helps you. I appreciate your vote very much!
    Mar 03, 2011 | fedora Linux Operating System
    How can i install in a edubuntu operating system
    You can install Edubuntu by creating a LiveCD or a LiveUSB. To do this visit this link and follow the instructions. Good luck and post back if you have questions.
    https://help.ubuntu.com/community/LiveCD
    Mar 02, 2011 | Canonical Ltd. Edubuntu 606 LTS Dapper...
    How to install windows 7 operating system
    To Install the Windows 7 Operating System (Win 7 OS):
    Instructions for a "Clean/New Windows 7 Installation:
    AFTER BACKING ALL YOUR DATA THAT YOU DON"T WANT TO LOSE, Do the Following :
    1) Insert your Genuine Windows 7 System Disc (Retail or OEM System Installation Disc).
    2) Close down all programs and restart your computer.
    3) As soon as the computer restarts, you should see a prompt that says something like this: "Press any key to boot from cd/dvd"
    ....So press any key!... This will boot to the installation disc and prepare for installation or repair (we are going to be installing windows, so ignore the repair options you see on the screen).
    *If you don't press a key in time, you will see that the computer will attempt to boot from the hard disc drive instead... if that happens, restart the computer and press a key when prompted.
    4) Depending on your particular Windows Version, you will see a prompt that says something about "Do you accept the license terms?" Click "Yes" or "I accept", etc.. and continue on...
    5) Choos Custom or Advanced Settings (the other option is for an upgrade..)
    6)Select the desired hard disc drive, (HDD aka Hard Drive), Select "Drive Options", and follow the onscreen instructions "Delete the partitions" (Do not Leave another windows installation on the same hard disc drive, unless you are experienced and know how to "dual-boot" properly!) Delete the Partitions.
    7) Now choose to install windows (be sure to select the newly deleted empty (unformatted) partition. Windows 7 will automatically format the drive for you and will begin to install windows 7. Follow the onscreen instructions and within a half an hour or less (depending on your hardware) you will be finished, just be sure not to leave the computer unattended while performing a windows installation, since it requires your input quite often to proceed.
    That's pretty much all there is to it!.. if you have any more trouble...
    Google it or Bing it.... Search Engines are awesome!.... Enjoy!
    *NOTE- If your windows 7 disc is a "Upgrade" disc, then you must perform an upgrade while running your previous/older windows version, since Windos Upgrade Discs aren't bootable, they simply patch the older version, replace system files, etc... to transform the previous windows installation into the target/newer version. If you want to perform a clean install, be sure you own a Windows 7 Installation / System Startup Disc.
    Jul 06, 2010 | Intel Motherboard
    A disk read error occurred saying Press Ctrl+Alt+Del to restart
    i would like to share few things to u.
    1.you can see the vista drives in federa but can't see federa drives on vista.
    2. 2ndly if u have burned any thing in the xp cd even a 1 kb file then the bootable disk will get corrupted and from next time u can not use that disk to install xp.
    borrow from ur friend and try again keeping above things in mind.
    one more thing if u want to use that 20gb then either u have to delete that partion from boot prompt only or u can also do it by partition magic only.
    Jun 13, 2009 | Compaq Presario 700 470024-192 Notebook
    fedora Linux Operating System Logo
    99 people viewed this question
    Top fedora Computers & Internet Experts
    alex metro
    alex metro
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    tdk1988
    Are you a fedora Computer and Internet Expert? Answer questions, earn points and help others
