Canon VIXIA HF10 HDV Camcorder
Problem for Canon VIXIA HF10 HDV Camcorder
HF10 camcorder cannot read some .mts files
By rajaffe on Jun 04, 2009
I recently recorded 240 clips (<2hrs@FXP) on a 16GB SDHC class 6 card (Transcend). The HF10 camcorder can only find the most recent 90 clips (~59 min in ~8GB). Both ImageMixer3 SE and iMovie will only download the files that the HF10 recognizes. Using a card reader, all 240 .mts files are present on the card and have appropriate file sizes. Canon support blames the card. iMovie doesn't like .mts files even if I rename them .m2ts. Any suggestions about recovering the HF10 unreadable files would be welcome.
Best Solution
posted on Jun 15, 2009
Very Helpful)
LadyChevalie
Rank: Apprentice
Rating: 97%, 8 votes
My knowledge in video editing is limited, but here's what I could dig up.
m2ts is also referred to as AVCHD, (MPEG4) a high-def Interlaced format which most computers cant render properly since most computers render in progressive format. You have to convert it to MPEG2, AVI, WMV, MOV or other movie file types in Progressive mode, a process known as "Deinterlacing" in order to edit it. Depending on how big the file is and how fast your computer is this could take several hours. Also, you cant view AVCHD files on normal televisions, you need a high-def TV.
If you want to edit high-def videos with post-effects and music etc, for dvd or blue-ray, you'll need a more powerful computer. The "recommended" minimum is a 64bit dual core processor, windows vista 64 bit, a seperate 500Gb or bigger hard drive and at minimum, 3-4Gbs of RAM with a high-def TV monitor. (1080i) Rendering High-Def videos is process heavy and can take up to 12+ hours to render a single 30-60 minute video with post-fx like music, logo's etc. The reason you need a 64bit processor and 64bit windows is because regular XP and Vista wont recognize more than 3Gb of RAM.
You could get by with a 32bit dual core processor and 2 gigs of RAM on windows XP, it's just going to be slower. You will still probably need a high def monitor if your going to edit in high-def mode.
High-def is new technology to mainstream consumers. Supporting technology hasnt caught up yet including most software--however most of what I read stated that Sony Vegas Platinum can do this pretty well.
Your camera is capeable of recording in progressive mode. You'll have to read the manual on how to do this. This will record it in standard mode which is not high-def. (For future reference)
To sum it all up, the camera's technology is more advanced than most PCs. I downloaded AVS Video Converter and converted the AVCHD, (MPEG4) a high-def Interlaced format to HD Video 720p: WMV9, 7000 kbps....... on the drop down screen of the AVS program. I now can view my videos in Progressive Standard mode with NO choppy play back or problems. Please note that 720p is a non digital standard Television view.
Remember M2ts files need to be converted to Progressive non HD files so your computer can read them. That will stop the choppy skips.
Hope this helps.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Aug 06, 2009
Helpful)
dacdist
Rank: Apprentice
Rating: 80%, 5 votes
Here are two things to try.
I had a problem with ImageMixer3 SE not recognizing all files. Turned out I had to use the USB port on the back of my desktop computer (motherboard) not the front USB port. There is some sort of front USB hub problem. Second you can try to update the ImageMixer3 SE software.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Nov 23, 2009
Not Rated)
imooding
Rank: Wiz
Rating: 84%, 19 votes
MTS to MPG Converter for Mac is designed for Mac users to convertMTS, M2TS videos to MPG, MPEG, MP4, MOV, M4V, AVI, MKV, 3GP, WMV, VOB,Divx, FLV, ASF, etc. It can also extract MTS M2TS audio to M4A, MP3,WAV, AC3, MKA, OGG audio formats.
Was this helpful?
Yes
No
Popular Solutions for Canon VIXIA HF10 HDV Camcorder
Questions and Unsolved Problems for Canon VIXIA HF10 HDV Camcorder
Do you recommend Canon VIXIA HF10 HDV Camcorder?
Answer
Answer
I just purchased vixia hf10, and opened the box and picked up camcorder, and noticed there is... (More)
Answer
How do I switch from recording to internal flash memory to recording to the sd card.
Answer
the camcorder was dropped on the front lens and now the shutter doesn't open. How can I open the... (More)
Answer
Canon Vixia hf10 was dropped. The lcd screen has no picture, only what looks like a crack with blue... (More)
Answer
my mac is no longer recognizing my canon vixia hf10 after having copied back a file from a PC back... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camcorder Experts
Top Camera & Camcorder Repairmen
in , OH
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
