Question about Foxconn P4M9007MB-8RS2H Motherboard
Mobo won't load my OS it stalls half way right before welcome scrren on xp
I just installed a new mobo and I plugged my hard drive in and turned it on and all i got was the black xp screen then it freezes and won't go any further please help.
Thanks
  • 661 Answers
You Shouldn't install a Mobo like that!!.
The Motherboard will require different drivers,  to operate correctly,   Windows will be trying to load the incorrect drivers and fail as it can't find the corresponding Hardware.
you may be able to get into safe mode,  delete almost everything in the Device manager tree, reboot and let it detect everything.
still you may have problems getting in.
also there is copy protection software in Windows which should detect the major hardware change and ask you to activate again.
If this fails you may have to try a Win XP repair (not using recovery console) which should rebuild windows, detect all your hardware, whilst not loosing all your data (although you may have to re-install some of your applications (as they may become dis-associated with the Registry.)
Posted on Oct 26, 2007
Have a 2005 a1250n Hp computer with Hp ver XP SP3 OS installed. MOBO failed. Can it be replaced by same p/n 5188 1936 using current all ready loaded XP OS. Will GUID be a problem?
If you can get the exact mobo you may replace it. No driver issue will raise. You can also buy a new mobo with same chipset and replace it. Same chipset mobo will require to install Sound, ethernet and vga drivers
Apr 12, 2016 | HP Computers & Internet
Getting system to recognize Hitachi CinemaStar P7K500
If you have OC that motherboard, roll it back. The drives that you are using are dinosaurs compared to the motherboard. Legacy issues exist.
Mar 03, 2017 | Hitachi CinemaStar 7K500 HCS725032VLA380...
Failed Southbridge in MSI P6NGM mobo
Whenever changing out a MB, you run the risk of having to do a complete re-install of Windows. A few caveats: If you choose a MB with exactly the same chipset and integrated peripherals, then you may only need to update a few drivers. Sometimes a repair install will do the trick, but there's no way to know until you complete the upgrade.
I absolutely agree with your idea to clone your boot partition to another drive if possible, then use the cloned drive to test the move to the new MB and see what hurdles you encounter.
Best suggestion is exact model replacement of the MB in question. Check Pricewatch.com
Feb 10, 2009 | MSI K7N2GM2-LSR Motherboard
After a hard drive falure I need to install windows xp
At this moment I have taken the HDD out of the case, bought an adapter for its 1.8" interfce and proceeded over the USB. I was, however, installing Linux, with practically no experience with Windows.
Oct 21, 2008 | Toshiba Portege R100 Tablet PC
Windows not loading
Appreciate the direct "Ask Me".
Whenever Microsoft Windows XP is installed on a system, the OS is binded to the motherboard, specifically to the chipsets. I am assuming that when you replaced the motherboard, the OS was not reinstalled and it was still binded to the original Dell Dimension board, most likely an Intel 925X Express chipset. When the OS started to load, it could not find the original 925X chipset and instead finds itself confronted with Biostar VIA P4M900/VT8237A chipsets which is an unknown, hence the BSOD.
You could try:
  • boot from CD drive with an XP installer and use the second repair option;
  • boot into Safe Mode (F8) and try to uninstall the Intel devices entries (except the CPU) and allow the system to auto detect (if it will) the new hardware;
  • backup your files and perform a fresh/clean install on the new motherboard.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 05, 2008 | Computers & Internet
PCI.SYS corrupt?
Do you have any kind of pci card that was or still is connected to the mobo ?
Jan 30, 2008 | ASUS P5VD2-MX SE Motherboard
SATA Drivers for Hitachi HDD
Is there a BIOS setting to temporarily put the SATA controller into legacy mode? XP would then think it's an IDE drive. Then, after installing XP, install the drivers from the motherboard CD, then go back into the BIOS and turn off legacy mode.
Jan 13, 2008 | Computers & Internet
Windows XP OEM OS
Yes, you have to purchase a new copy of Windows XP... Or alternatively you can try a freeware operating system such as UBUNTU. It does basically the same stuff your Windows did, just with a little more flair! http://www.ubuntu.com/
Sep 25, 2007 | Microsoft Windows XP Home Edition
Crashing during Windows Setup
Check out any hardware that doesnot supports windows xp. remove that and reload the os. it works. or remove all the additional addon cards like modem, network card, printers etc., (just maintain only hard disk, cd rom and floppy drive)then install the os. once os installs add the components one by one to so that the os will detect one by one cheers!
Sep 17, 2006 | Microsoft Windows XP Professional for PC
Foxconn P4M9007MB-8RS2H Motherboard Logo
71 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
