Question about Fuji FinePix F480 Digital Camera
My finepix f480 says !ZOOM ERROR on power up and switches off. Any suggestions as to whats wrong?
  • 244 Answers
Does the lens retract and extend fully? Because of the design of the lens It is possible that the internal lens has jammed or is damaged. click on my profile and email me and I may be able to help
Posted on Jun 04, 2009
Fuji film finepixF480 showing focus error
Possible that the lens mechanism is jammed , sometimes the flexible connector of the lens focus/zoom can be faulty.You try to check for some tips from the link below; http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2011 | Fuji FinePix F480 Digital Camera
FinePix F480. Zoom keeps coming out at an angle and jamming so that it won't return into casing.This gives 'Zoom Errors.'
The lens needs to be replaced, or if you can try and SNAP the lens back towards center so it's not at an angle you might be able to fix it. Most likely not though, and you will have to replace the lens.
Thomas
Sep 12, 2011 | Fuji FinePix F480 Digital Camera
Error zoom finepix s1000 fd
My first suggestion is to remove batteries and put a new set inside of the camera. Sometime the power fluctuation will jam the mechanism and give you a zoom error. If this does not solve your problem then the lens is probably damaged or out of alignment and needs to be serviced. I suggest you look for the local service center; I know Photo Tech is the authorized service center in NYC. www.phototech.com and they do most of those repairs at their facility.
Good Luck,
Paul
Jun 30, 2011 | Fuji FinePix S1000FD Digital Camera
ZOOM ERROR
Camera malfunction or fault.
Turn the camera on again,taiking care no to touch the lens
Turn the camera off an on again ,if the message still apears ,contact your fujifilm dealer.
Dec 16, 2010 | Fuji FinePix F480 Digital Camera
When i turn on the camera fuji f480 digital camers it shows me zoom error on screen
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2010 | Fuji FinePix A400 Digital Camera
Zoom Error for Fujifilm FinePix F480...Lens not contracting
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Feb 26, 2009 | Fuji FinePix F480 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Mar 06, 2008 | Fuji FinePix Z1 Digital Camera
ZOOM ERROR
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Fuji FinePix F480 Digital Camera Logo
467 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
