Question about Amana ALW880WH Top Load Washer
The washer won't fill with cold water. Disconnected the hose from the washer and turned on the cold water, no water. How do I replace the valve in the wall?
    Sniper:
  • 67 Answers
Your first step would be go and buy a new valve. by that way, buy a roll of teflon tape as well (the white, very thin one). then turn off your main water valve and open up one working valve to release the pressure then take a bucket and place it under the valve to replace now screw off the old valve. remeber hwo it was fitted. now take some of the teflon tape and wind it arround the new valves mounting thread. this will do the sealing, so the water does not take its way thru the mounting. now screw in the new valve. pull it tight. take a second view wether you did it right. keep the bucket under the valve open main water valve. check your new valve. everything sealed? water running when open? YES? Great! You did it. dont forget to remove the bucket, you are done
Posted on Jun 04, 2009
Maytag LSE7806ACE washer won't rinse. Machine fills with water and agitates, spins also. Just won"t rinse......help!!!!!!!
Your washer uses cold water only for the rinse cycle.
Start you washer and put the water temperature switch on 'cold' to see if you have any cold water.
If you find that there is no cold water then turn the water off and remove the cold water hose from the back of the washer.
Once you have the cold water hose removed you will be able to look in the water valve and check the screen. A lot of times the screens get plugged up and need to be cleaned. The screen will just pull out of the valve so you can rinse it out good.
Make sure to put the screen back in place.
If you have no cold water and the screen is clean then you will need to replace the water inlet valve.
Aug 03, 2011 | Washing Machines
Cold water fills very slowly
Turn off the water, remove the cold water hose at the back of the washer ... inside you will find a hose washer with a screen on it - remove and replace it. I believe you will discover the screen is clogged. While you have the hose disconnected, run some water into a bucket from the hose to clean it as well.
Jun 19, 2010 | Kenmore 24032\24036 Top Load Washer
Cold water fill is super slow
Do this:
1. Un-plug the washing machine
2. Shut off the cold water supply valve to the machine and then disconnect the cold water hose at the machine. Place a small container under the fitting when you do this to catch the water that will probably leak out.
3. Place the disconnected end of the hose in a bucket or the sink if you have one and SLOWLY turn the cold water back on. make sure the water pressure coming out of the hose is good. If so, the problem isn't there. Turn the valve back off.
4. Set the disconnected hose aside. Take a good look at the connection on the machine (where you disconnected the hose). There should be an inlet screen. It's common for these screens to plug up once in a while, especially if you are on well water. Remove the screen and clean it, being careful to not lose the washer. The screen can be rinsed out in a sink. Look for any other debris that may be in this connection.
5. Re-install the screen, re-install, the hose, turn the water back on slowly, and check for leaks. Plug the machine back in.
6. Try filling the machine again with the washer empty, just in case some muck also comes out so you don't stain your clothes.
7. If it works ok, you're done. If not, then the water fill valve itself may not be working properly and may need to be replaced.
8. A weak electrical connection to the fill valve can also cause this condition, but it's usually the inlet screen.
Good Luck and re-post if you have further questions!
Feb 02, 2010 | Washing Machines
I can't get the cold water to fill the tub/rinse. the hot works.
Your problem is either a clogged COLD fill valve or a bad water fill valve. Turn the water off. Remove the COLD hose from the WASHER. Check the filter screen inside the valve for sediment. If you find sediment,remove the screen and clean it. Replace the screen and turn the water back on. If you do not find sediment on the screen,replace the water valve.
Sep 21, 2009 | Frigidaire FWS1339A Top Load Washer
Cold water enters washer very slowly
First - check the water inlet hose screen for calcium or rust build-up.
If cold water is filling slowly, take these steps:
  1. Unplug the washer.
  2. Turn off the cold water supply faucet.
  3. Remove the fill hose connected to the back of the washer.
  4. Checkthe fill screen on the cold water inlet valve for debris or depositsthat can restrict the water flow. If necessary, you can carefully pullthe screen out and clean it. Flush the inlet thoroughly and replace thescreen. NOTE: If debris makes it past this screen, it can cause thevalve to leak and cause a flood in your laundry room. Monitor thewasher for this type of problem is you pull the screen out and clean it.
  5. Placethe end of the hose in a bucket and briefly turn on the faucet to checkfor proper pressure and flow from the cold water hose. If waterpressure from the cold inlet water hose is bad, check the hose forclogs. If the hose is okay, then I recommend calling a plumber to checkthe water supply to your washer cold water faucet.
  6. If the above checks do not help you resolve the fill problem, you will likely need to replace the inlet fill valve.
Your cold water fill valve (mixer valve) solenoid has failed if after cleaning - the condition remains.
CLICK HERE for a replacement part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 24, 2009 | Roper RAS8445KQ Top Load Washer
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
When washer fills with cold water there is very little pressure and it takes forever to fill.
Turn off the cold water valve.
Remove the cold water hose from the washer. Clean out the filter screen on the water valve. Replace the hose and run the washer.
Apr 21, 2009 | Washing Machines
Washer will not fill with cold water during cycle
it sounds like your mixture valve is faulty on the cold water side. that is the valve where you screw the hose ends on. it needs to be replaced you can purchase one at your local sears, be sure to take your make and model number with you
Dec 31, 2008 | Washing Machines
Washer won't stop filling
The mixing valve that is part of the connector where the hose is attached has either failed or is disconnected electrically.
These are simple to replace and not too expensive.
You may have gotten some debris into the valve assembly which is being held open and is a sealed device.
If this is the case, it will probably not be removable since the valve is trying to close and will only open if voltage is applied.
Aug 24, 2008 | Frigidaire CWS3600AS Top Load Washer
GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Mar 01, 2007 | GE WHRE5260E Top Load Washer
Amana ALW880WH Top Load Washer Logo
495 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
